[postgis-users] Problem displaying postgis data with maapserver
strk at refractions.net
Wed Mar 9 13:31:15 PST 2005
Looks like an bug in mappostgis.c ... ask on mapserver lists.
--strk;
On Wed, Mar 09, 2005 at 06:36:21PM +0000, Shaq Gbadebo wrote:
> Hi!
> I have sorted out an initial problem, which was my postgresql server was
> not not set for tcp/ip connections. But now here is the error I am getting.
> msDrawMap(): Image handling error. Failed to draw layer named 'test'.
> prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query)
> statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d()),'NDR'),OID::text from HBHB WHERE
> && setSRID('BOX3D(-1333332 -999999,1333332 999999)'::BOX3D,
> find_srid('','HBHB','') )'
> Postgresql reports the error ''
> More Help:
> Error with POSTGIS data variable. You specified '<check your .map file>'.
> Standard ways of specifiying are :
> (1) 'geometry_column from geometry_table'
> (2) 'geometry_column from (<sub query>) as foo using unique <column name>
> using SRID=<srid#>'
> Make sure you put in the 'using unique <column name>' and 'using SRID=#'
> clauses in.
> For more help, please see http://postgis.refractions.net/documentation.php
> Mappostgis.c - version of June 12/2003.
> msPOSTGISLayerParseData(): Query error. Error parsing POSTGIS data
> variable. Must contain 'geometry_column from table_name' or 'geom from
> (subselect) as foo' (couldnt find ' from '). More help:
> Error with POSTGIS data variable. You specified 'geom FROM test'.
> using SRID=<srid#>'
> clauses in.
> Any sort of help would be appreciated.
> Thanks
> Shaq.
> postgis-users mailing list
