[postgis-users] geometry column
Ethan Alpert
ealpert at digitalglobe.com
Thu Mar 10 12:31:22 PST 2005
Look at the description of geometry_columns. Latitude should be a string
afaict. Same for public, circle and polygon
-e
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of w m
Sent: Wednesday, March 09, 2005 9:17 PM
To: postgis
Subject: [postgis-users] geometry column
Hi
Im tryin to populate my geometry column in my postgresql
database usin pgadmin
i get the following errors (i have also included a screen
snapshot)
SQL error:
ERROR: column "latitude" does not exist
In statement:
INSERT INTO "geometry_columns" ("f_table_catalog",
"f_table_schema", "f_table_name", "f_geometry_column",
"coord_dimension", "srid", "type", "attrelid", "varattnum", "stats")
VALUES (Latitude, public, 'Hotspots', circle, '45.5177', '1', polygon,
'1', '1', '1')
i have a column called latitude in my table hotspots.
is it necessary to enter values in each field??
in the coord_dimension field does i have to be x,y format or can
it be any value or does it have to be the latitudes
im doing all this because i would like to use this command
pgsql2shp...but first i need to fill the geometry column because
otherwise i get the following error
-bash-2.05b$ pgsql2shp Montreal Hotspots
Initializing... No geometry column found.
The DBF file will be created but not the shx or shp files.
Done.
Dumping: XX [4 rows]
Thank You
Nisa
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050310/984e964a/attachment.html>
