[postgis-users] Intersection() throws error?
Hubert Fröhlich
hubert.froehlich at bvv.bayern.de
Fri Mar 11 04:10:22 PST 2005
Hi list,
I am currently using PostgreSQL 8.0.0 final, GEOS 2.1.1 and Postgis
1.0.0 RC 1
I want to check the correct neighborhood of land use parcels.
I tried
SELECT intersects ( 'MULTIPOLYGON(((4424942.57 5359069.45,4424953.01
5359069.19,4424969 5359068.79,4424984.98 5359068.39,4425000.97
5359067.99,4425016.95 5359067.58,4425032.94 5359067.18,4425048.92
5359066.78,4425058.49 5359066.54,4425078.28 5359067.74,4425086.75
5359067.58,4425097.49 5359067.38,4425099.91 5359067.68,4425101.89
5359068.48,4425103.54 5359069.77,4425104.7 5359071.42,4425104.9
5359073.06,4425106.4 5359072.35,4425106.69 5359051.7,4425104.75
5359051.62,4425104.66 5359054.77,4425104.1 5359056.28,4425101.86
5359057.96,4425099.19 5359058.5,4425086.71 5359058.82,4425068.4
5359059.29,4425050.09 5359059.75,4425031.78 5359060.22,4425013.46
5359060.68,4424995.15 5359061.15,4424976.84 5359061.61,4424953.66
5359062.2,4424942.04 5359062.49,4424942.03692
5359062.49009,4424941.70709 5359062.49184,4424941.37754
5359062.47806,4424941.04901 5359062.44877,4424940.72222
5359062.40403,4424940.3979 5359062.34395,4424940.07677
5359062.26866,4424939.75955 5359062.17832,4424939.44693
5359062.07315,4424939.13961 5359061.95336,4424938.83828
5359061.81923,4424938.5436 5359061.67105,4424938.25623
5359061.50916,4424937.9768 5359061.33391,4424937.70594
5359061.14569,4424937.44425 5359060.94492,4424937.1923
5359060.73204,4424937.19 5359060.73,4424937.18532
5359060.72574,4424936.94678 5359060.49794,4424936.71924
5359060.25916,4424936.5032 5359060.00992,4424936.29914
5359059.75078,4424936.10752 5359059.48232,4424935.92875
5359059.20513,4424935.76324 5359058.91983,4424935.61135
5359058.62704,4424935.47342 5359058.32743,4424935.34976
5359058.02165,4424935.24064 5359057.71039,4424935.14631
5359057.39433,4424935.06697 5359057.07418,4424935.00279
5359056.75064,4424934.95393 5359056.42445,4424934.92049
5359056.09631,4424934.92 5359056.09,4424936.52 5359076.19,4424937.15
5359072.9,4424939.37 5359070.43,4424942.57 5359069.45)))',
'MULTIPOLYGON(((4424933.2 5359035.11,4424934.92 5359056.09,4424934.92049
5359056.09631,4424934.95393 5359056.42445,4424935.00279
5359056.75064,4424935.06697 5359057.07418,4424935.14631
5359057.39433,4424935.24064 5359057.71039,4424935.34976
5359058.02165,4424935.47342 5359058.32743,4424935.61135
5359058.62704,4424935.76324 5359058.91983,4424935.92875
5359059.20513,4424936.10752 5359059.48232,4424936.29914
5359059.75078,4424936.5032 5359060.00992,4424936.71924
5359060.25916,4424936.94678 5359060.49794,4424937.18532
5359060.72574,4424937.19 5359060.73,4424937.1923
5359060.73204,4424937.44425 5359060.94492,4424937.70594
5359061.14569,4424937.9768 5359061.33391,4424938.25623
5359061.50916,4424938.5436 5359061.67105,4424938.83828
5359061.81923,4424939.13961 5359061.95336,4424939.44693
5359062.07315,4424939.75955 5359062.17832,4424940.07677
5359062.26866,4424940.3979 5359062.34395,4424940.72222
5359062.40403,4424941.04901 5359062.44877,4424941.37754
5359062.47806,4424941.70709 5359062.49184,4424942.03692
5359062.49009,4424942.04 5359062.49,4424953.66 5359062.2,4424952.87
5359031.74,4424948.16 5359031.86,4424948.26 5359034.7,4424933.2
5359035.11)))' );
intersects
t
(1 row)
so far ok but when using the same polygons to get the true intersection
SELECT astext(intersection( 'MULTIPOLYGON(((4424942.57
5359069.45,4424953.01 5359069.19,4424969 5359068.79,4424984.98
5359068.39,4425000.97 5359067.99,4425016.95 5359067.58,4425032.94
5359067.18,4425048.92 5359066.78,4425058.49 5359066.54,4425078.28
5359067.74,4425086.75 5359067.58,4425097.49 5359067.38,4425099.91
5359067.68,4425101.89 5359068.48,4425103.54 5359069.77,4425104.7
5359071.42,4425104.9 5359073.06,4425106.4 5359072.35,4425106.69
5359051.7,4425104.75 5359051.62,4425104.66 5359054.77,4425104.1
5359056.28,4425101.86 5359057.96,4425099.19 5359058.5,4425086.71
5359058.82,4425068.4 5359059.29,4425050.09 5359059.75,4425031.78
5359060.22,4425013.46 5359060.68,4424995.15 5359061.15,4424976.84
5359061.61,4424953.66 5359062.2,4424942.04 5359062.49,4424942.03692
5359035.11)))' ) );
NOTICE: AssertionFailedException: EdgeRing::computePoints: found null
Directed Edge
ERROR: GEOS Intersection() threw an error!
What has gone wrong?
Sorry for the long and complicated polygons; they have been converted
from multi-"polygons" containing not only straight lines but also
circular arcs (This holds especially for the parts with four or five
decimal digits.)
Greetings,
Hubert
Dr.-Ing. Hubert Fröhlich
Bezirksfinanzdirektion München
Alexandrastr. 3, D-80538 München, GERMANY
Tel. :+49 (0)89 / 2190 - 2980
Fax :+49 (0)89 / 2190 - 2997
hubert dot froehlich at bvv dot bayern dot de
