[postgis-users]CONNECTION to database thru Mapserver
Ethan Alpert
ealpert at digitalglobe.com
Mon Mar 14 13:44:06 PST 2005
Maybe there's a case sensitivity problem. Try using all lower case for
your db name.
-e
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of w m
Sent: Monday, March 14, 2005 2:33 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users]CONNECTION to database thru
Mapserver
the configuration files are fine and they allow the
connections....but still to no avail after changing STATUS to DEFAULT i
still get the same errors. if i change STATUS to ON i dont see the
points on the map but tehre are no errors.....
Doug_Newcomb at fws.gov wrote:
Wokar,
Check your postgresql.conf file to see if you are
allowing tcp/ip
connections and your pg_hba.conf file to see if you are
allowing
connections from 132.205.108.60
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not
representative of the
official policy of the U.S.Fish and Wildlife Service or
Dept. of Interior.
I left my signature file in /dev/null
| | w m |
| | Sent by: |
| | postgis-users-bounces at postgis.refr|
| | actions.net |
| | 03/14/2005 02:12 PM |
| | Please respond to PostGIS Users |
| | Discussion |
| To: PostGIS Users Discussion |
| cc: |
thru Mapserver |
Thanks for your reply. when I changed my STAUS to
Default it gives me the
following error:
msDrawMap(): Image handling error. Failed to draw layer
named 'Hotspots'.
msPOSTGISLayerOpen(): Query error. couldnt make
connection to DB with
connect string 'user=project password=test
dbname=Montreal
host=132.205.108.60'.
Error reported was 'could not connect to server:
Connection refused Is the
server running on host "132.205.108.60" and accepting
TCP/IP connections on
port 5432? '.
This error occured whe n trying to make a connection to
the specified
postgresql server.
Most commonly this is caused by
(1) incorrect connection string
(2) you didnt specify a 'user=...' in your connection
string
(3) the postmaster (postgresql server) isnt running
(4) you are not allowing TCP/IP connection to the
postmaster
(5) your postmaster is not running on the correct port -
if its not on 5432
you must specify a 'port=...'
(6) the security on your system does not allow the
webserver (usually user
'nobody') to make socket connections to the post master
(7) you forgot to specify a 'host=...' if the postmaster
is on a different
machine
(8) you made a typo
My server is running, what I am not sure is (4) and (5).
Can you please
explain me how can I check the above. Also the user name
and password is
the user name and password for the database right?
pram at pramcentral.com wrote:
----- Original Message -----
To: "PostGIS Users Discussion"
Mapserver
Date: Mon, 14 Mar 2005 09:02:56 -0800 (PST)
> Thank You for your response.
> i made the changes that you suggested but i still have
no luck in
> displaying the points on the map. I'm not sure if a
connection is
> being established to the database or not...how can i
know that??
> and instead of local host i also tried to insert the
ip address of
> my server but it still didnt work nor did i get any
errors.
> any help would be appreciated greately
> thank you
> wokar
> LAYER
> CONNECTIONTYPE postgis
> NAME "Spots" # my table name
> CONNECTION "user=test password=test dbname=MyDataBase
host=localhost"
> DATA "the_geom FROM Spots" # the_geom column from
table Spots
> STATUS ON
> TYPE POINT
> CLASS
> COLOR 0 0 0
> OUTLINECOLOR 0 0 0
> SIZE 2
> END
> ; END
Have you tried with STATUS DEFAULT instead of STATUS ON
-Prashanth
HTMLX.com
Mapserver, Mapscript, PHP Hosting
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection
around
http://mail.yahoo.com
Do you Yahoo!?
Yahoo! Small Business - Try our new resources site!
<http://us.rd.yahoo.com/evt=31637/*http://smallbusiness.yahoo.com/resour
ces/>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050314/c473602d/attachment.html>
