[postgis-users] Memory leak in translate function in RC3
strk at refractions.net
Wed Mar 16 03:28:12 PST 2005
Bryce, I've gone through the code and enforced some other early memory
release. I can't see any real leak though...
Can you send the output of explain analyze for the query ?
Also, 268435456 is a BIG number for a single alloc...
maybe it's the postgres buffer growing ?
Can you also check sum(mem_size(shape)) from crs_feature_name; ?
--strk;
On Wed, Mar 16, 2005 at 05:42:54PM +1300, Bryce Watkins wrote:
> Hi strk,
> I have defiantly found a leak this time :-) in that if I run the following
> query I get out of memory error, and also watching the postgresql process on
> the box shows the memory consumption continually increasing over time,
> whilst the query is running.
> SELECT crs_feature_name.id, crs_feature_name."type", crs_feature_name.name,
> crs_feature_name.status, crs_feature_name.other_details,
> astext(translate(crs_feature_name.shape, 160, 0, 0)) AS shape
> FROM crs_feature_name
> inner join crs_parcel on crs_feature_name.id = crs_parcel.fen_id
> limit 100;
> Translate seems to work fine if it's used on its own, but when combining
> with astext or transform then this is the output (from astext combination
> anyway).
> ERROR: out of memory
> DETAIL: Failed on request of size 268435456.
> This has only shown up since RC2 as far as I can tell.
> Cheers,
> Bryce.
> postgis-users mailing list
