[postgis-users] Unusual Make/Compilation Error - postgis-1.0.0-rc3
Tomeh, Husam
htomeh at firstam.com
Wed Mar 16 11:14:26 PST 2005
Under src subdirectory, I see only Makefile.global.in , not
Makefile.global.
And under src directory, there's a "makefile" subdirectory which has
Makefile.solaris ; but I can see Makefile.port.
Yes I did set up PGSQL_SRC to /p01/postgresql-8.0.1
Husam
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
strk at refractions.net
Sent: Wednesday, March 16, 2005 9:39 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Unusual Make/Compilation Error -
postgis-1.0.0-rc3
On Wed, Mar 16, 2005 at 09:25:44AM -0800, Tomeh, Husam wrote:
> Hello,
> According to the sysadmin, the make I used is a GNU make.
Weird... do you have the PGSQL_SRC variable set ?
Does setting it to base source of postgresql help ?
Is your postgresql source tree configured ?
--strk;
> Thanks,
> anadev10#pkginfo -l SMCmake
> PKGINST: SMCmake
> CATEGORY: application
> ARCH: sparc
> VERSION: 3.80
> BASEDIR: /usr/local
> VENDOR: Free Software Foundation
> PSTAMP: Steve Christensen
> INSTDATE: Mar 15 2005 13:51
> EMAIL: steve at smc.vnet.net
> STATUS: completely installed
> FILES: 50 installed pathnames
> 5 shared pathnames
> 7 directories
> 1 executables
> 4661 blocks used (approx)
> Sent: Friday, March 11, 2005 10:24 PM
> To: postgis-users at postgis.refractions.net
> postgis-1.0.0-rc3
> On Fri, Mar 11, 2005 at 04:11:17PM -0800, Tomeh, Husam wrote:
> > I have installed PostgreSQL 8 on my Solaris 2.8 dev machine. I
> > installed
> > Proj.4 and GEOS spatial libraries and have been trying to install
> > the PostGIS library with no luck so far. I downloaded and extracted
> > postgis-1.0.0-rc3 under the the contrib subdirectory. When I run
> > "make", I get errors not finding other Making.* files under "src". I
> > checked for these Making.* files and they do exist!! However; I keep
> > getting the following errors when I run "make":
> You need GNU make, try 'gmake' instead of 'make' and see if it fixes
> the problem.
> --strk;
> > anadev10 /p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3 :) make
> > make -C lwgeom
> > make[1]: Entering directory
> > `/p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3/lwgeom'
> > ../Makefile.config:90: /src/Makefile.global: No such file or
> > directory
> > Makefile:98: /src/Makefile.shlib: No such file or directory
> > make[1]: *** No rule to make target `/src/Makefile.shlib'. Stop.
> > make[1]: Leaving directory
> > make: *** [liblwgeom] Error 2
> > Any idea is highly appreciated. Thanks,
> > Husam
> > ** This message contains confidential information intended only for
> > the use of the addressee(s) named above and may contain information
> > that is legally privileged. If you are not the addressee, or the
> > person responsible for delivering it to the addressee, you are
> > hereby notified that reading, disseminating, distributing or copying
> > this message is strictly prohibited. If you have received this
> > message by mistake, please immediately notify us by replying to the
> > message and delete the original message immediately thereafter.
> > Thank you. FADLD Tag
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
