[postgis-users] Unusual Make/Compilation Error - postgis-1.0.0-rc3
strk at refractions.net
Fri Mar 18 09:17:47 PST 2005
On Fri, Mar 18, 2005 at 08:24:05AM -0800, Tomeh, Husam wrote:
> Although I did run configure before; however, running it again did help.
> I ran into another error (see below). Is setting up postgis on a Linux
> more straightforward than Solaris? Or it does not matter really?
Try current CVS, it contains the parser files already so you don't
have to generate them again.
--strk;
> Thanks..
> anadev10 /p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3 :) make make -C
> lwgeom
> make[1]: Entering directory
> `/p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3/lwgeom'
> sh ../geos_version.sh /usr/local > postgis_geos_version.h bison -y -vd
> -p lwg_parse_yy wktparse.y
> make[1]: *** [wktparse.tab.c] Broken Pipe
> make[1]: Leaving directory
> make: *** [liblwgeom] Error 2
> Husam
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Sent: Wednesday, March 16, 2005 11:16 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Unusual Make/Compilation Error -
> postgis-1.0.0-rc3
> On Wed, Mar 16, 2005 at 11:14:26AM -0800, Tomeh, Husam wrote:
> > Under src subdirectory, I see only Makefile.global.in , not
> > Makefile.global.
> This usually means you didn't run ./configure from within
> --strk;
> > And under src directory, there's a "makefile" subdirectory which has
> > Makefile.solaris ; but I can see Makefile.port.
> > Yes I did set up PGSQL_SRC to /p01/postgresql-8.0.1
> > Husam
> > Sent: Wednesday, March 16, 2005 9:39 AM
> > postgis-1.0.0-rc3
> > On Wed, Mar 16, 2005 at 09:25:44AM -0800, Tomeh, Husam wrote:
> > > Hello,
> > > According to the sysadmin, the make I used is a GNU make.
> > Weird... do you have the PGSQL_SRC variable set ?
> > Does setting it to base source of postgresql help ?
> > Is your postgresql source tree configured ?
> > --strk;
> > > Thanks,
> > > anadev10#pkginfo -l SMCmake
> > > PKGINST: SMCmake
> > > CATEGORY: application
> > > ARCH: sparc
> > > VERSION: 3.80
> > > BASEDIR: /usr/local
> > > VENDOR: Free Software Foundation
> > > PSTAMP: Steve Christensen
> > > INSTDATE: Mar 15 2005 13:51
> > > EMAIL: steve at smc.vnet.net
> > > STATUS: completely installed
> > > FILES: 50 installed pathnames
> > > 5 shared pathnames
> > > 7 directories
> > > 1 executables
> > > 4661 blocks used (approx)
> > > Sent: Friday, March 11, 2005 10:24 PM
> > > To: postgis-users at postgis.refractions.net
> > > postgis-1.0.0-rc3
> > > On Fri, Mar 11, 2005 at 04:11:17PM -0800, Tomeh, Husam wrote:
> > > > I have installed PostgreSQL 8 on my Solaris 2.8 dev machine. I
> > > > installed
> > > > Proj.4 and GEOS spatial libraries and have been trying to install
> > > > the PostGIS library with no luck so far. I downloaded and
> > > > extracted
> > > > postgis-1.0.0-rc3 under the the contrib subdirectory. When I run
> > > > "make", I get errors not finding other Making.* files under "src".
> > > > I
> > > > checked for these Making.* files and they do exist!! However; I
> > > > keep
> > > > getting the following errors when I run "make":
> > > You need GNU make, try 'gmake' instead of 'make' and see if it fixes
> > > the problem.
> > > --strk;
> > > > make -C lwgeom
> > > > ../Makefile.config:90: /src/Makefile.global: No such file or
> > > > directory
> > > > Makefile:98: /src/Makefile.shlib: No such file or directory
> > > > make[1]: *** No rule to make target `/src/Makefile.shlib'. Stop.
> > > > Any idea is highly appreciated. Thanks,
> > > > Husam
> > > > ** This message contains confidential information intended only
> > > > for the use of the addressee(s) named above and may contain
> > > > information that is legally privileged. If you are not the
> > > > addressee, or the person responsible for delivering it to the
> > > > addressee, you are hereby notified that reading, disseminating,
> > > > distributing or copying
> > > > this message is strictly prohibited. If you have received this
> > > > message by mistake, please immediately notify us by replying to
> > > > the message and delete the original message immediately
> thereafter.
> > > > Thank you. FADLD Tag
> > > > _______________________________________________
> > > > postgis-users mailing list
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
