[postgis-users] Installation Error - postgis-1.0.0-rc4
Tomeh, Husam htomeh at firstam.com
Mon Mar 21 11:51:58 PST 2005
When SA attempt to install it, it complain about "-C" of make.
anadev10#pwd
/p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc4
anadev10#make install
make -C lwgeom
Usage : make [ -f makefile ][ -K statefile ]... [ -d ][ -dd ][ -D ][ -DD
             [ -e ][ -i ][ -k ][ -n ][ -p ][ -P ][ -q ][ -r ][ -s ][ -S
][ -t ]
             [ -u ][ -w ][ -V ][ target... ][ macro=value... ][ "macro
+=value"... ]
make: Fatal error: Unknown option `-C'
*** Error code 1
make: Fatal error: Command failed for target `liblwgeom'
___________________________________________
This is the make we have on that server:
anadev10#pkginfo -l SMCmake
> > > > >    PKGINST:  SMCmake
> > > > >   CATEGORY:  application
> > > > >       ARCH:  sparc
> > > > >    VERSION:  3.80
> > > > >    BASEDIR:  /usr/local
> > > > >     VENDOR:  Free Software Foundation
> > > > >     PSTAMP:  Steve Christensen
> > > > >   INSTDATE:  Mar 15 2005 13:51
> > > > >      EMAIL:  steve at smc.vnet.net
> > > > >     STATUS:  completely installed
> > > > >      FILES:       50 installed pathnames
> > > > >                    5 shared pathnames
> > > > >                    7 directories
> > > > >                    1 executables
> > > > >                 4661 blocks used (approx)
  Husam
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Tomeh, Husam
Sent: Monday, March 21, 2005 11:27 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Compilation Error - postgis-1.0.0-rc4
That worked. Thanks for your help. Compiled perfectly.
strk at refractions.net
Sent: Monday, March 21, 2005 11:21 AM
Subject: Re: [postgis-users] Compilation Error - postgis-1.0.0-rc4
On Mon, Mar 21, 2005 at 10:22:03AM -0800, Tomeh, Husam wrote:
> Thanks. I created the patch file and placed it on postgis. I ran
> "patch < Makefile.patch" and got this error:
>   Looks like a unified context diff.
>   I can't seem to find a patch in there anywhere.
> Was this the right procedure to install your patch?
> Thanks,
Do it manually.. it basically quotes grep argument:
	grep -v ^#
becomes:
	grep -v '^#'
--strk;
>   Husam
> Sent: Monday, March 21, 2005 9:30 AM
> On Mon, Mar 21, 2005 at 09:23:37AM -0800, Tomeh, Husam wrote:
> > Since I'm still having problems with rc3, I downloaded rc4. I get
> > the following error when running make:
> > cpp -P -traditional-cpp -DUSE_VERSION=80 lwpostgis.sql.in | sed -e
> > 's:@MODULE_FILENAME@:\$libdir/liblwgeom.so.1.0:g;s:@POSTGIS_VERSION@
> > :1
> > .0
> > USE_GEOS=1 USE_PROJ=1
> > USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:0.2.1:g;s/@POSTGIS_BUILD_D
> > AT
> > E@
> > /2005-03-21 17:13:03/g' | grep -v ^# > lwpostgis.sql
> Apply this patch and see what happen:
> Index: lwgeom/Makefile
> RCS file: /home/cvs/postgis/postgis/lwgeom/Makefile,v
> retrieving revision 1.72
> diff -U2 -r1.72 Makefile
> --- lwgeom/Makefile     18 Mar 2005 12:43:23 -0000      1.72
> +++ lwgeom/Makefile     21 Mar 2005 17:46:41 -0000
> @@ -139,5 +139,5 @@
>  lwpostgis.sql: lwpostgis.sql.in
> -       cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< | sed
-e
> 's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(POSTGI
> S_
> VERSION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@POSTGIS
> _B UILD_DATE@/$(POSTGIS_BUILD_DATE)/g' | grep -v ^# > $@
> +       cpp -P -traditional-cpp -DUSE_VERSION=$(USE_VERSION) $< | sed
> + -e
> + 's:@MODULE_FILENAME@:$(MODULE_FILENAME):g;s:@POSTGIS_VERSION@:$(POST
> + GI
> + S_VERSION):g;s:@POSTGIS_SCRIPTS_VERSION@:$(SCRIPTS_VERSION):g;s/@POS
> + TG IS_BUILD_DATE@/$(POSTGIS_BUILD_DATE)/g' | grep -v '^#' > $@
>  install: all installdirs install-lwgeom-lib install-lwgeom-scripts
> --strk;
> > cp lwpostgis.sql ..
> > Usage: grep -hblcnsviw pattern file . . .
> > cp: cannot access lwpostgis.sql
> > make[1]: *** [../lwpostgis.sql] Error 2
> > make[1]: Leaving directory
> > `/p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc4/lwgeom'
> > make: *** [liblwgeom] Error 2
> > Any thoughts?
> > Thanks,
> >   Husam
> > Sent: Friday, March 18, 2005 9:18 AM
> > Subject: Re: [postgis-users] Unusual Make/Compilation Error -
> > postgis-1.0.0-rc3
> > On Fri, Mar 18, 2005 at 08:24:05AM -0800, Tomeh, Husam wrote:
> > > Although I did run configure before; however, running it again did
> > help.
> > > I ran into another error (see below). Is setting up postgis on a
> > > Linux
> > > more straightforward than Solaris? Or it does not matter really?
> > Try current CVS, it contains the parser files already so you don't
> > have to generate them again.
> > --strk;
> > > Thanks..
> > > anadev10 /p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3 :) make
> > > make -C lwgeom
> > > make[1]: Entering directory
> > > `/p01/postgresql-8.0.1/contrib/postgis-1.0.0-rc3/lwgeom'
> > > sh ../geos_version.sh /usr/local > postgis_geos_version.h bison -y
> > > -vd
> > > -p lwg_parse_yy wktparse.y
> > > make[1]: *** [wktparse.tab.c] Broken Pipe
> > >   Husam
> > > Of strk at refractions.net
> > > Sent: Wednesday, March 16, 2005 11:16 AM
> > > postgis-1.0.0-rc3
> > > On Wed, Mar 16, 2005 at 11:14:26AM -0800, Tomeh, Husam wrote:
> > > > Under src subdirectory, I see only Makefile.global.in , not
> > > > Makefile.global.
> > > This usually means you didn't run ./configure from within
> > > --strk;
> > > > And under src directory, there's a "makefile" subdirectory which
> > > > has
> > > > Makefile.solaris ; but I can see Makefile.port.
> > > > Yes I did set up PGSQL_SRC to /p01/postgresql-8.0.1
> > > >  Husam
> > > > Sent: Wednesday, March 16, 2005 9:39 AM
> > > > postgis-1.0.0-rc3
> > > > On Wed, Mar 16, 2005 at 09:25:44AM -0800, Tomeh, Husam wrote:
> > > > > Hello,
> > > > > According to the sysadmin, the make I used is a GNU make.
> > > > Weird... do you have the PGSQL_SRC variable set ?
> > > > Does setting it to base source of postgresql help ?
> > > > Is your postgresql source tree configured ?
> > > > --strk;
> > > > > Thanks,
> > > > >    PKGINST:  SMCmake
> > > > >       ARCH:  sparc
> > > > >    VERSION:  3.80
> > > > >    BASEDIR:  /usr/local
> > > > >                    5 shared pathnames
> > > > >                    7 directories
> > > > >                    1 executables
> > > > > Behalf
> > > > > Sent: Friday, March 11, 2005 10:24 PM
> > > > > To: postgis-users at postgis.refractions.net
> > > > > postgis-1.0.0-rc3
> > > > > On Fri, Mar 11, 2005 at 04:11:17PM -0800, Tomeh, Husam wrote:
> > > > > > I have installed PostgreSQL 8 on my Solaris 2.8 dev machine.
> > > > > > I
> > > > > > installed
> > > > > > Proj.4 and GEOS spatial libraries and have been trying to
> > > > > > install the PostGIS library with no luck so far. I
> > > > > > downloaded and extracted
> > > > > > postgis-1.0.0-rc3 under the the contrib subdirectory. When I
> > > > > > run
> > > > > > "make", I get errors not finding other Making.* files under
> > "src".
> > > > > > I
> > > > > > checked for these Making.* files and they do exist!!
> > > > > > However; I keep
> > > > > > getting the following errors when I run "make":
> > > > > You need GNU make, try 'gmake' instead of 'make' and see if it
> > > > > fixes
> > > > > the problem.
> > > > > --strk;
> > > > > > make
> > > > > > make -C lwgeom
> > > > > > ../Makefile.config:90: /src/Makefile.global: No such file or
> > > > > > directory
> > > > > > Makefile:98: /src/Makefile.shlib: No such file or directory
> > > > > > make[1]: *** No rule to make target `/src/Makefile.shlib'.
> > Stop.
> > > > > > Any idea is highly appreciated. Thanks,
> > > > > >    Husam
This message contains confidential information intended only for the
use of the addressee(s) named above and may contain information that
is legally privileged.  If you are not the addressee, or the person
responsible for delivering it to the addressee, you are hereby
notified that reading, disseminating, distributing or copying this
message is strictly prohibited.  If you have received this message by
mistake, please immediately notify us by replying to the message and
delete the original message immediately thereafter.
Thank you.                                       FADLD Tag
