[postgis-users] How to start the postgres service without root privilege
Tiger Wings tigerwings at gmail.com
Tue Mar 22 12:08:58 PST 2005
I got it. Thank you.
One more question:
I tried to test the /examples/ogc_test_suite
after I run: psql ogc_test_suite < ../../lwpostgis.sql
an error occurs:
ERROR:  current transaction is aborted, commands ignored until end of
transaction block
Many thanks.
T. W.
On Tue, 22 Mar 2005 18:55:15 +0100, strk at refractions.net
<strk at refractions.net> wrote:
> On Tue, Mar 22, 2005 at 11:36:09AM -0600, Tiger Wings wrote:
> > I did so.
> > But when execute psql, an error occurs:
> > database "tiger" does not exist.
> psql -l # gives you the list of existing databases
> createdb # will create database "tiger" (your login name)
> createdb other # will create database "other"
> Be aware to use the commands under $HOME/... not the
> system ones. If you intended to run another server
> on the system databases you just can't, unless you
> have write privileges on them.
> --strk;
> > Thank you.
> > T. W.
> > On Tue, 22 Mar 2005 09:58:09 +0100, strk at refractions.net
> > > On Mon, Mar 21, 2005 at 08:26:16PM -0600, Tiger Wings wrote:
> > > > Hi there,
> > > > I built postgresql 8.0 from the source code under Linux.
> > > > But I don't have root right on the system.
> > > > How can start the db server from my own directory?
> > > > Thanks a lot.
> > > Install under your homedir,
> > > Specify an arbitrary port not clashing with other running procs
> > > above 1024, and a datadir again under your home.
> > > $HOME/pgsql/bin/initdb #initialize the database
> > > $HOME/pgsql/bin/pg_ctl start # start the postmaster
> > > $HOME/pgsql/bin/psql # connect
> > > --strk;
> > > > Cheers
> > > > T.W.
> > > > _______________________________________________
> > > > postgis-users mailing list
> > > > postgis-users at postgis.refractions.net
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
