[postgis-users] Change default "canonical form" of spatial objects
strk at refractions.net
Tue Mar 22 22:17:15 PST 2005
On Tue, Mar 22, 2005 at 07:53:23PM -0300, Gustavo Henrique Sberze Ribas wrote:
> Hello,
> Is it possible to change the "canonical form" of spatial
> objects in an uncomplicated way? :)
> The current form is HEXEWKB for ascii and I'd like it to
> be EWKT. I mean, I'd like the following statements to
> produce the same output:
> - SELECT geom FROM table;
> - SELECT AsEWKT(geom) FROM table;
> I'm currently running PG 7.4.6 with PostGIS RC2.
The only way to change canonical output form is modifying
the C code. Canonical form is complicated for the sake
of precision.
If using asewkt() is a pain for many people we might
consider adding a function like:
SELECT postgis_set("ascii_canonical_form", "ewkt");
SELECT postgis_set("ascii_canonical_form", "wkt");
SELECT postgis_set("ascii_canonical_form", "hexwkb");
--strk;
> Thanks,
> postgis-users mailing list
