Res: Re: [postgis-users] Problem on Instalation on Fedora Core 3
EZEQUIAS RODRIGUES DA ROCHA ezequias at recife.pe.gov.br
Mon May 2 13:30:41 PDT 2005
Dear Strik
I unpack the postgis-0.9.0 folder to the system folder:
/usr/local/pgsql/lib/pgxs/src/contrib/postgis-0.9.0
Amd proceed the instalation, but see the error above that appears to me:
[root at dc_geolivre postgis-0.9.0]# make
Makefile:67: ../../src/Makefile.global: Arquivo ou diretório não encontrado
Makefile:189: /src/Makefile.shlib: Arquivo ou diretório não encontrado
make: *** Sem regra para processar o alvo `/src/Makefile.shlib'.  Pare.
[root at dc_geolivre postgis-0.9.0]# pwd
Best Regards
Ezequias Rodrigues da Rocha
Strk at refractions.net Escrito :
> On Mon, May 02, 2005 at 09:45:10AM -0300, Ezequias Rodrigues da Rocha wrote:
> > Hello,^M
> > ^M
> > This is my first one message to the list.^M
> Please try to avoid those ^M chars in the next one ;)
> X-Mailer: IncrediMail (3501710)
> ^^^^^^^ it's all its fault probably.
> It seems mutt (www.mutt.org) fixed them after postpone/edit.
> > There is a problem to install the postgis 0.9.0 I would like to know how
> to
> > solve.
> > I unpack postgis (postgis-0.9.0.tar.gz) at  folder
> usr/local/pgsql/contrib/
> > So I changed the line 45 of file "Makefile" from: subdir=contrib/postgis
> to:
> > subdir=contrib/postgis-0.9.0 and   started the procedure to install the
> > postgis
> > [root at localhost postgis-0.9.0]# make
> encontrado
> > Translation of the latest line: make: *** Whitout roule to process target
> I suggest you set LANG=C before sending bug reports, it should do
> the translation on your behalf (correct me if I'm wrong).
> > I would like to know what is wrong with it.
> > Please tell me what I did wrong.
> It seems you unpacked postgis in the postgresql INSTALLATION dir,
> while you should have done so in the postgresql SOURCE dir.
> Also remember to configure the postgresql source tree before attempting
> to build postgis.
> > Best Regards
> Good luck!
> --strk;
> postgis-users mailing list
______________________________
EMPREL, http://www.recife.pe.gov.br
