Res: Re: [postgis-users] Problem on Instalation on Fedora Core 3
strk at refractions.net
Mon May 2 10:40:26 PDT 2005
On Mon, May 02, 2005 at 01:30:41PM +0000, EZEQUIAS RODRIGUES DA ROCHA wrote:
> Dear Strik
> I unpack the postgis-0.9.0 folder to the system folder:
> /usr/local/pgsql/lib/pgxs/src/contrib/postgis-0.9.0
> Amd proceed the instalation, but see the error above that appears to me:
> [root at dc_geolivre postgis-0.9.0]# make
> Makefile:67: ../../src/Makefile.global: Arquivo ou diretório não encontrado
> Makefile:189: /src/Makefile.shlib: Arquivo ou diretório não encontrado
> make: *** Sem regra para processar o alvo `/src/Makefile.shlib'. Pare.
> [root at dc_geolivre postgis-0.9.0]# pwd
Again I don't speek your language, US I would be able to understand.
Again, you need postgresql *sources*. Are postgresql sources
located under /usr/local/pgsql/lib/pgxs/src ?
PostGIS does NOT support pgxs yet.
--strk;
> Best Regards
> Ezequias Rodrigues da Rocha
> Strk at refractions.net Escrito :
> > On Mon, May 02, 2005 at 09:45:10AM -0300, Ezequias Rodrigues da Rocha wrote:
> > > Hello,^M
> > > ^M
> > > This is my first one message to the list.^M
> > Please try to avoid those ^M chars in the next one ;)
> > X-Mailer: IncrediMail (3501710)
> > ^^^^^^^ it's all its fault probably.
> > It seems mutt (www.mutt.org) fixed them after postpone/edit.
> > > There is a problem to install the postgis 0.9.0 I would like to know how
> > to
> > > solve.
> > > I unpack postgis (postgis-0.9.0.tar.gz) at folder
> > usr/local/pgsql/contrib/
> > > So I changed the line 45 of file "Makefile" from: subdir=contrib/postgis
> > to:
> > > subdir=contrib/postgis-0.9.0 and started the procedure to install the
> > > postgis
> > > [root at localhost postgis-0.9.0]# make
> > encontrado
> > > Translation of the latest line: make: *** Whitout roule to process target
> > I suggest you set LANG=C before sending bug reports, it should do
> > the translation on your behalf (correct me if I'm wrong).
> > > I would like to know what is wrong with it.
> > > Please tell me what I did wrong.
> > It seems you unpacked postgis in the postgresql INSTALLATION dir,
> > while you should have done so in the postgresql SOURCE dir.
> > Also remember to configure the postgresql source tree before attempting
> > to build postgis.
> > > Best Regards
> > Good luck!
> > --strk;
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> EMPREL, http://www.recife.pe.gov.br
