Res: Re: Res: Re: [postgis-users] Problem on Instalation on Fedora Core 3
strk at refractions.net
Mon May 2 11:48:36 PDT 2005
On Mon, May 02, 2005 at 03:36:15PM +0000, EZEQUIAS RODRIGUES DA ROCHA wrote:
> Strk,
> Sorry but I do not know how to change the language of Postgresql that's why I didn't change it.
> About the src directory, I don't believe there is a source directory here on my instalation.
> Let us see the roo Postgresql directory:
> drwxr-xr-x 9 root root 4096 Mai 2 13:36 .
> drwxr-xr-x 13 root root 4096 Abr 29 11:05 ..
> drwxr-xr-x 2 root root 4096 Abr 29 11:07 bin
> drwx------ 8 postgres root 4096 Abr 29 16:53 data
> drwxr-xr-x 3 root root 4096 Abr 29 11:05 doc
> drwxr-xr-x 6 root root 4096 Abr 29 11:07 include
> drwxr-xr-x 3 root root 4096 Abr 29 11:07 lib
> drwxr-xr-x 4 root root 4096 Abr 29 11:05 man
> drwxr-xr-x 3 root root 4096 Abr 29 11:07 share
> And the only src directory I found is:
> [root at dc_geolivre pgsql]# find . -name src
> /lib/pgxs/src
> What should I do to continuing the instalation without the source files of Postgresql ?
> What is my next step ?
Getting sources ;)
Or.. if you feel adventurous get a snapshot of latest postgis CVS
and try that instead.
--strk;
> Best Regards
> Ezequias
> Strk at refractions.net Escrito :
> > On Mon, May 02, 2005 at 01:30:41PM +0000, EZEQUIAS RODRIGUES DA ROCHA wrote:
> > > Dear Strik
> > > I unpack the postgis-0.9.0 folder to the system folder:
> > > /usr/local/pgsql/lib/pgxs/src/contrib/postgis-0.9.0
> > > Amd proceed the instalation, but see the error above that appears to me:
> > > [root at dc_geolivre postgis-0.9.0]# make
> > > Makefile:67: ../../src/Makefile.global: Arquivo ou diretório não
> > encontrado
> > > Makefile:189: /src/Makefile.shlib: Arquivo ou diretório não encontrado
> > > make: *** Sem regra para processar o alvo `/src/Makefile.shlib'. Pare.
> > > [root at dc_geolivre postgis-0.9.0]# pwd
> > Again I don't speek your language, US I would be able to understand.
> > Again, you need postgresql *sources*. Are postgresql sources
> > located under /usr/local/pgsql/lib/pgxs/src ?
> > PostGIS does NOT support pgxs yet.
> > --strk;
> > > Best Regards
> > > Ezequias Rodrigues da Rocha
> > Escrito :
> > > > On Mon, May 02, 2005 at 09:45:10AM -0300, Ezequias Rodrigues da Rocha
> > wrote:
> > > > > Hello,^M
> > > > > ^M
> > > > > This is my first one message to the list.^M
> > > > Please try to avoid those ^M chars in the next one ;)
> > > > X-Mailer: IncrediMail (3501710)
> > > > ^^^^^^^ it's all its fault probably.
> > > > It seems mutt (www.mutt.org) fixed them after postpone/edit.
> > > > > There is a problem to install the postgis 0.9.0 I would like to know
> > how
> > > > to
> > > > > solve.
> > > > > I unpack postgis (postgis-0.9.0.tar.gz) at folder
> > > > usr/local/pgsql/contrib/
> > > > > So I changed the line 45 of file "Makefile" from:
> > subdir=contrib/postgis
> > > > to:
> > > > > subdir=contrib/postgis-0.9.0 and started the procedure to install
> > the
> > > > > postgis
> > > > > [root at localhost postgis-0.9.0]# make
> > > > encontrado
> > Pare.
> > > > > Translation of the latest line: make: *** Whitout roule to process
> > target
> > > > I suggest you set LANG=C before sending bug reports, it should do
> > > > the translation on your behalf (correct me if I'm wrong).
> > > > > I would like to know what is wrong with it.
> > > > > Please tell me what I did wrong.
> > > > It seems you unpacked postgis in the postgresql INSTALLATION dir,
> > > > while you should have done so in the postgresql SOURCE dir.
> > > > Also remember to configure the postgresql source tree before attempting
> > > > to build postgis.
> > > > > Best Regards
> > > > Good luck!
> > > > --strk;
> > > > _______________________________________________
> > > > postgis-users mailing list
> > > > postgis-users at postgis.refractions.net
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > > EMPREL, http://www.recife.pe.gov.br
