[postgis-users] parametrized domains
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Tue May 3 06:09:55 PDT 2005
Hi guys,
FWIW, what was Tom's response to this? I guess that since he is not on
postgis-users (and the moderator isn't around), his reply didn't get through
to the list much like his answer below didn't.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Paul Ramsey
> Sent: 29 April 2005 18:41
> To: Tom Lane
> Cc: strk at refractions.net; PostGIS Users Discussion
> Subject: Re: [postgis-users] parametrized domains
> How about something that allows us to parameterize the type
> after it is
> declared in the statement, as with the PRIMARY KEY, DEFAULT,
> etc, notations:
> CREATE TABLE mygeotable (
> id SERIAL PRIMARY KEY,
> geom GEOMETRY NOT NULL PARAMETERS(4326,2),
> inserted TIMESTAMP DEFAULT NOW()
> P.
> Tom Lane wrote:
> > strk at refractions.net writes:
> >>The most elegant solution would be to specify that at table
> creation
> >>time. Something you already use with 'varchar' - for
> >>example:
> >> CREATE TABLE test ( a varchar(10); )
> >> CREATE TABLE test ( geom geometry(4326); )
> >>We asked Tom Lane about this, but he saied the parser were
> not ready
> >>for this kind of extensibility. I cc him so if he have news
> will let
> >>us know.
> > It's still not :-(. Only datatypes that are hard-wired into the
> > grammar can have parameters. My recollection is that this looks
> > extremely difficult to change, because "foo(n)" looks far too much
> > like a function call if foo is not a keyword known in
> advance to the
> > grammar. We'd probably have to adopt some other notation instead.
> > regards, tom lane
> postgis-users mailing list postgis-users at postgis.refractions.net
