[postgis-users] parametrized domains
strk at refractions.net strk at refractions.net
Tue May 3 23:34:29 PDT 2005
On Tue, May 03, 2005 at 02:09:55PM +0100, Mark Cave-Ayland wrote:
> Hi guys,
> FWIW, what was Tom's response to this? I guess that since he is not on
> postgis-users (and the moderator isn't around), his reply didn't get through
> to the list much like his answer below didn't.
I got no response, but a response would go to Paul if any.
I think it takes someone to pick that up and make a grammar
proposal.
--strk;
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 791021
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of Paul Ramsey
> > Sent: 29 April 2005 18:41
> > To: Tom Lane
> > Cc: strk at refractions.net; PostGIS Users Discussion
> > Subject: Re: [postgis-users] parametrized domains
> > How about something that allows us to parameterize the type
> > after it is
> > declared in the statement, as with the PRIMARY KEY, DEFAULT,
> > etc, notations:
> > CREATE TABLE mygeotable (
> > 	id SERIAL PRIMARY KEY,
> > 	geom GEOMETRY NOT NULL PARAMETERS(4326,2),
> > 	inserted TIMESTAMP DEFAULT NOW()
> > P.
> > Tom Lane wrote:
> > > strk at refractions.net writes:
> > >>The most elegant solution would be to specify that at table
> > creation
> > >>time. Something you already use with 'varchar' - for
> > >>example:
> > >>	CREATE TABLE test ( a varchar(10); )
> > >>	CREATE TABLE test ( geom geometry(4326); )
> > >>We asked Tom Lane about this, but he saied the parser were
> > not ready
> > >>for this kind of extensibility. I cc him so if he have news
> > will let
> > >>us know.
> > > It's still not :-(.  Only datatypes that are hard-wired into the
> > > grammar can have parameters.  My recollection is that this looks
> > > extremely difficult to change, because "foo(n)" looks far too much
> > > like a function call if foo is not a keyword known in
> > advance to the
> > > grammar.  We'd probably have to adopt some other notation instead.
> > > 			regards, tom lane
> > postgis-users mailing list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
