[postgis-users] crashing PostgreSQL connections
James Marca jmarca at translab.its.uci.edu
Tue May 3 12:34:38 PDT 2005
Sorry, I deleted the thread already, but there was a message this
morning about crashing postgis/postgresql
The result so far was
psql -U slash -d crash -c "SELECT GeometryFromText('POINT(-106 40.67)', -1);"
              geometryfromtext
 01010000000000000000805AC0F6285C8FC2554440
(1 row)
I had a similar crashing problem last week related to typos and
casting, as in
'SRID=32611; POINT(414160.003328498 3726591.60052614)'::geometry
(I think I picked up the ::geometry  idiom  from the docs)
I found out that typos here cause catastrophic failures.
First, note that casting works if typed correctly:
james at emma:~$ psql -U slash -d crash -c "SELECT 'SRID=32611;POINT(414160.003328498 3726591.60052614)'::geometry;"
                      geometry
 0101000020637F0000B88B680340471941620ADECC7F6E4C41
(1 row)
but typos cause more severe errors, as in (double close parens):
james at emma:~$ psql -U slash -d crash -c "SELECT 'SRID=32611;POINT(414160.003328498 3726591.60052614))'::geometry;"
server closed the connection unexpectedly
        This probably means the server terminated abnormally
        before or while processing the request.
connection to server was lost
and LINESTRING with one point, not two
james at emma:~$ psql -U slash -d crash -c "SELECT 'SRID=32611;LINESTRING(414160.003328498 3726591.60052614)'::geometry;"
Using GeomFromEWKT is much more stable:
james at emma:~$ psql -U slash -d crash -c "SELECT geomfromewkt('SRID=32611;POINT(414160.003328498 3726591.60052614))')"
ERROR:  parse error - invalid geometry
and
james at emma:~$ psql -U slash -d crash -c "SELECT geomfromewkt('SRID=32611;LINESTRING(414160.003328498 3726591.60052614)')"
ERROR:  geometry requires more points
The moral for me was to find and fix all places in my Java where I
cast to ::geometry and instead use GeomFromEWKT().
I have no idea how casting works in postgresql/postGIS.  Is it
supposed to be this fragile, or can it be made to be an alias for
GeomFromText or GeomFromEWKT instead?
James
