[postgis-users] Re: Bugus SRS
Frank Warmerdam fwarmerdam at gmail.com
Thu May 5 08:30:27 PDT 2005
On 5/5/05, strk at refractions.net <strk at refractions.net> wrote:
> Nicolas, we just changed the entry you pointed our attention on:
> SRID=27582
> You reported it worked for you with entries shipped with postgis
> pre 1.0.0:
> That entry already had a lon_0 != 0.
> Since these entries are extracted by a script in gdal/ogr
> I think it's worth fixing them in the source data repository
> first.
> Frank, did you check this out lately ?
Strk,
I am aware of outstanding problems with the NTF coordinate systems.
I think the problem is related to the non-greenwich prime meridian
but it could also be related to the use of gradians.   There is an
open bug report on the issue, but I haven't dug into it.
Best regards,
