[postgis-users] How do you use PostGIS?
Paul Ramsey
pramsey at refractions.net
Thu May 5 09:47:54 PDT 2005
Martin Daly wrote:
> As part of an OS MM benchmarking exercise, we have created tables of up
> to ~60 million rows. The resulting database, which has several tables
> containing a total of ~72 million rows, is ~29Gb on disk. A pre-LWGEOM
> database containing the same data was ~39Gb. Much as I'd like to share
> the benchmark results with you, Oracle licensing precludes us from doing
> so.
You can't share the comparison, but you could tell us the PostGIS raw
numbers and the hardware specs? All data is good data :)
Paul
