RES: [postgis-users] How does PostGIS know Units?
Gustavo Henrique Sberze Ribas gribas at cpqd.com.br
Fri May 6 09:57:55 PDT 2005
Hello,
 The following command transforms a point from lat/long WGS84 to
UTM, uses buffer() to create a 250Km radius circle and transform
that circle back to lat/long coordinates.
 I don't known if that's the smartest way do to this, but it
works. :)
 select
 transform(
   setSRID(
      buffer(
         transform(
           'SRID=4326;POINT(-47.2407989501953 -22.7394008636475)',32723
	 250000
      32723
   4326
Gustavo
> >> Yes, PostGIS assumes all your units are the same. Which
> means that if
> >> you are working in degrees, buffer will also work in
> degrees. Which is
> >> probably not what you want. You will want to choose a planar
> >> projection to work in that is suitable to your data.
> > Great!  But how do I go about doing this?  Like I said, I'm
> still very
> > new to PostGIS?  Let's say my full SQL is:
> >     select AsText( Buffer( PointFromText( 'POINT(39.0
> -83.4)' ),125.0 ) );
> > What should I do to choose a planar projection so that PostGIS
> > understands that my POINT is given in lat/lon and that
> Buffer() is using
> > km?
> You reproject your points *into* the planar projection, and
> then perform
> the calculation as before... what is the extent of your data?
> That will
> inform your choice of projection.
> > And will I need the Proj4 module for this (in case I don't already
> > have it)?
> Yes you'll need proj4. select postgis_full_version for a list of
> libraries (I think).
> postgis-users mailing list
