RES: [postgis-users] How does PostGIS know Units?
Paul Ramsey pramsey at refractions.net
Fri May 6 10:47:34 PDT 2005
You'll want to be sure to use a UTM zone appropriate to your data, but
yes, this works fine. One could wrap this in a PL/PgSQL function to make
it simpler for operational use.
Gustavo Henrique Sberze Ribas wrote:
> Hello,
>  The following command transforms a point from lat/long WGS84 to
> UTM, uses buffer() to create a 250Km radius circle and transform
> that circle back to lat/long coordinates.
>  I don't known if that's the smartest way do to this, but it
> works. :)
>  select
>  transform(
>    setSRID(
>       buffer(
>          transform(
>            'SRID=4326;POINT(-47.2407989501953 -22.7394008636475)',32723
> 	 250000
>       32723
>    4326
> Gustavo
>>>>Yes, PostGIS assumes all your units are the same. Which
>>means that if
>>>>you are working in degrees, buffer will also work in
>>degrees. Which is
>>>>probably not what you want. You will want to choose a planar
>>>>projection to work in that is suitable to your data.
>>>Great!  But how do I go about doing this?  Like I said, I'm
>>still very
>>>new to PostGIS?  Let's say my full SQL is:
>>>    select AsText( Buffer( PointFromText( 'POINT(39.0
>>-83.4)' ),125.0 ) );
>>>What should I do to choose a planar projection so that PostGIS
>>>understands that my POINT is given in lat/lon and that
>>Buffer() is using
>>>km?
>>You reproject your points *into* the planar projection, and
>>then perform
>>the calculation as before... what is the extent of your data?
>>That will
>>inform your choice of projection.
>>>And will I need the Proj4 module for this (in case I don't already
>>>have it)?
>>Yes you'll need proj4. select postgis_full_version for a list of
>>libraries (I think).
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
