[postgis-users] postgis bool::text and mapserver
Didrik Pinte dpinte at itae.be
Mon May 9 07:14:16 PDT 2005
I have a problem using the latest Postigs package of the Debian GIS
project with Debian/Sarge Mapserver package (4.4).
When using boolean in EXPRESSION, the test does not work. And nothing
displays...
For example :
Here is the mapserver class :
                CLASS
                        NAME "test"
                        EXPRESSION ([moved] = 't')
                        COLOR 255 0 0
                        OUTLINECOLOR 255 0 0
                        SIZE 10
                        SYMBOL "circle"
                END
And here is the table definition  :
CREATE TABLE mapping
  id varchar(50) NOT NULL,
  moved bool DEFAULT false,
  cartopoint geometry,
  CONSTRAINT id PRIMARY KEY (id),
  CONSTRAINT enforce_dims_cartopoint CHECK (ndims(cartopoint) = 2),
  CONSTRAINT enforce_geotype_cartopoint CHECK (geometrytype(cartopoint)
= 'POINT'::text OR cartopoint IS NULL),
  CONSTRAINT enforce_srid_cartopoint CHECK (srid(cartopoint) = 4326)
When using psql, it works perfectly well :
select text(moved) from tblgeomapping where text(moved)='t';
As anybody an idea on the source of the problem ?
Thanks a lot in advance for any help.
Didrik Pinte
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050509/112bdaef/attachment.pgp>
