[postgis-users] postgis bool::text and mapserver
Paul Ramsey pramsey at refractions.net
Mon May 9 07:26:35 PDT 2005
Two possible things:
SELECT true::text
and see what the text representation to boolean is.
I think to do string comparisons in mapserver you use 'eq' instead of
Paul
On 9-May-05, at 7:14 AM, Didrik Pinte wrote:
> Hi,
> I have a problem using the latest Postigs package of the Debian GIS
> project with Debian/Sarge Mapserver package (4.4).
> When using boolean in EXPRESSION, the test does not work. And nothing
> displays...
> For example :
> Here is the mapserver class :
>                 CLASS
>                         NAME "test"
>                         EXPRESSION ([moved] = 't')
>                         COLOR 255 0 0
>                         OUTLINECOLOR 255 0 0
>                         SIZE 10
>                         SYMBOL "circle"
>                 END
> And here is the table definition  :
> CREATE TABLE mapping
>   id varchar(50) NOT NULL,
>   moved bool DEFAULT false,
>   cartopoint geometry,
>   CONSTRAINT id PRIMARY KEY (id),
>   CONSTRAINT enforce_dims_cartopoint CHECK (ndims(cartopoint) = 2),
>   CONSTRAINT enforce_geotype_cartopoint CHECK (geometrytype(cartopoint)
> = 'POINT'::text OR cartopoint IS NULL),
>   CONSTRAINT enforce_srid_cartopoint CHECK (srid(cartopoint) = 4326)
> When using psql, it works perfectly well :
> select text(moved) from tblgeomapping where text(moved)='t';
> As anybody an idea on the source of the problem ?
> Thanks a lot in advance for any help.
> Didrik Pinte
> postgis-users mailing list
