[postgis-users] postgis bool::text and mapserver
Didrik Pinte dpinte at itae.be
Mon May 9 07:37:00 PDT 2005
Le lundi 09 mai 2005 à 07:26 -0700, Paul Ramsey a écrit :
> Two possible things:
> SELECT true::text
> and see what the text representation to boolean is.
> I think to do string comparisons in mapserver you use 'eq' instead of
> Paul
Hi Paul,
Here are the information :
[1] ::text conversion
test=# select true::text;
 text
 t
(1 ligne)
I've also tested if there is no hidden whitespace over there :
nh3=# select char_length(true::text);
 char_length
           1
(1 ligne)
[2] Mapserver EXPRESSION :
I've just tested my expression like this :
EXPRESSION ( [moved] eq 't')
but it does not work ...
When I export the information to a shapefile, it works great.
Didrik
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050509/043d1c9c/attachment.pgp>
