[postgis-users] Re: Expression Mapserver
Vojtech Honzik v.honzik at gmail.com
Mon May 9 10:00:11 PDT 2005
>Hi Steve,
>Here are all my tests :
>EXPRESSION ( [moved] = 't')
>EXPRESSION ( [moved] = "t")
>EXPRESSION ( [moved] eq 't')
>EXPRESSION ( [moved] eq "t")
>EXPRESSION ( [moved] =~ /t/)
>None of those test work
>Didrik
I use expression ('[moved]' eq 't'). It says Mapserver to compare the value
of moved as string with another string. At least I think so.
Vojtech Honzik
----- Original Message -----
From: <postgis-users-request at postgis.refractions.net>
To: <postgis-users at postgis.refractions.net>
Sent: Monday, May 09, 2005 6:45 PM
Subject: postgis-users Digest, Vol 31, Issue 23
> Send postgis-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> postgis-users-owner at postgis.refractions.net
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of postgis-users digest..."
> Today's Topics:
>   1. postgis bool::text and mapserver (Didrik Pinte)
>   2. pgsql2shp changing case of fieldnames (Obe, Regina     DND\MIS)
>   3. Re: postgis bool::text and mapserver (Paul Ramsey)
>   4. Re: postgis bool::text and mapserver (Didrik Pinte)
>   5. Re: postgis bool::text and mapserver (Stephen Woodbridge)
>   6. How to reproject postgis layers in mapserver
>   7. Re: postgis bool::text and mapserver (Didrik Pinte)
>   8. Re: pgsql2shp changing case of fieldnames (strk at refractions.net)
>   9. Re: postgis bool::text and mapserver (Didrik Pinte)
> Message: 1
> Date: Mon, 09 May 2005 16:14:16 +0200
> From: Didrik Pinte <dpinte at itae.be>
> Subject: [postgis-users] postgis bool::text and mapserver
> To: postgis-users at postgis.refractions.net
> Message-ID: <1115648056.1274.25.camel at geru-itea>
> Content-Type: text/plain; charset="us-ascii"
> Hi,
> I have a problem using the latest Postigs package of the Debian GIS
> project with Debian/Sarge Mapserver package (4.4).
> When using boolean in EXPRESSION, the test does not work. And nothing
> displays...
> For example :
> Here is the mapserver class :
>                CLASS
>                        NAME "test"
>                        EXPRESSION ([moved] = 't')
>                        COLOR 255 0 0
>                        OUTLINECOLOR 255 0 0
>                        SIZE 10
>                        SYMBOL "circle"
>                END
> And here is the table definition  :
> CREATE TABLE mapping
>  id varchar(50) NOT NULL,
>  moved bool DEFAULT false,
>  cartopoint geometry,
>  CONSTRAINT id PRIMARY KEY (id),
>  CONSTRAINT enforce_dims_cartopoint CHECK (ndims(cartopoint) = 2),
>  CONSTRAINT enforce_geotype_cartopoint CHECK (geometrytype(cartopoint)
> = 'POINT'::text OR cartopoint IS NULL),
>  CONSTRAINT enforce_srid_cartopoint CHECK (srid(cartopoint) = 4326)
> When using psql, it works perfectly well :
> select text(moved) from tblgeomapping where text(moved)='t';
> As anybody an idea on the source of the problem ?
> Thanks a lot in advance for any help.
> Didrik Pinte
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Name: not available
> Type: application/pgp-signature
> Desc: This is a digitally signed message part
> Url :
> http://lists.refractions.net/pipermail/postgis-users/attachments/20050509/112bdaef/attachment-0001.bin
> Message: 2
> Date: Mon, 9 May 2005 10:18:52 -0400
> From: "Obe, Regina     DND\\MIS" <robe.dnd at cityofboston.gov>
> Subject: [postgis-users] pgsql2shp changing case of fieldnames
> To: 'PostGIS Users Discussion' <postgis-users at postgis.refractions.net>
> Message-ID: <B318FD8D29DCD411BD0500D0B7A91C6704103EAB at jupiter>
> I noticed the 3/31/05 build of pgsql2shp I have now automatically forces
> the
> output field names to upper case which normally would be a good thing.
> Unfortunately I've got some old mapserver maps that rely on the field
> names
> in the dbf being in lowercase.  Is there anyway to reverse this behavior
> e.g. with a switch or something of that sort so that I don't have to
> revert
> back to the older version of pgsql2shp?
> Thanks,
> Regina
> An HTML attachment was scrubbed...
> URL:
> http://lists.refractions.net/pipermail/postgis-users/attachments/20050509/19e68b1f/attachment-0001.html
> Message: 3
> Date: Mon, 09 May 2005 07:26:35 -0700
> From: Paul Ramsey <pramsey at refractions.net>
> Subject: Re: [postgis-users] postgis bool::text and mapserver
> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Message-ID: <8c087af6cfc5c48dcc8a46c62d0b7416 at refractions.net>
> Content-Type: text/plain; format=flowed; charset=US-ASCII
> Two possible things:
> SELECT true::text
> and see what the text representation to boolean is.
> I think to do string comparisons in mapserver you use 'eq' instead of
> Paul
> On 9-May-05, at 7:14 AM, Didrik Pinte wrote:
>> Hi,
>> displays...
>> For example :
>>                 CLASS
>>                         NAME "test"
>>                         COLOR 255 0 0
>>                         SIZE 10
>>                         SYMBOL "circle"
>>                 END
>> Didrik Pinte
> Message: 4
> Date: Mon, 09 May 2005 16:37:00 +0200
> Message-ID: <1115649420.1274.30.camel at geru-itea>
> Content-Type: text/plain; charset="iso-8859-15"
>> SELECT true::text
>> Paul
> Hi Paul,
> Here are the information :
> [1] ::text conversion
> test=# select true::text;
> text
> t
> (1 ligne)
> I've also tested if there is no hidden whitespace over there :
> nh3=# select char_length(true::text);
> char_length
>           1
> (1 ligne)
> [2] Mapserver EXPRESSION :
> I've just tested my expression like this :
> but it does not work ...
> When I export the information to a shapefile, it works great.
> Didrik
> Name: not available
> Url :
> http://lists.refractions.net/pipermail/postgis-users/attachments/20050509/043d1c9c/attachment-0001.bin
> Message: 5
> Date: Mon, 09 May 2005 10:56:17 -0400
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> Message-ID: <427F7A11.8030300 at swoodbridge.com>
> Content-Type: text/plain; charset=ISO-8859-15; format=flowed
> Try EXPRESSION ( [moved] =~ /t/)
> -Steve
>>>SELECT true::text
>>>Paul
>> Hi Paul,
>>  text
>>  t
>> (1 ligne)
>>  char_length
>>            1
>> (1 ligne)
>> Didrik
> Message: 6
> Date: Mon, 9 May 2005 10:58:36 -0400
> Subject: [postgis-users] How to reproject postgis layers in mapserver
> Message-ID: <B318FD8D29DCD411BD0500D0B7A91C6704103EAD at jupiter>
> I'm using mapserver 4.4.2 and PostGIS 8.0.2/1.0.0/proj 4.4.9.  I have
> aerial
> tiles of MrSID files in NAD 83 meters  and my postgis layers in NAD 83 ft.
> If I have my map in NAD 83 ft most works fine - I can zoom in out etc. and
> its fairly fast.  My aerial reprojects correctly to NAD 83 ft.
> If I perform a query something like
> qstring=parcel_id=blahblahblah&qlayer=parcels in my htm file
> - then my aerial layer gets all screwed up - it doesn't seem to reproject
> correctly. It takes a long time to run and then the whole aerial seems to
> get squashed at the center of the zoomed in parcel.  If I leave the aerial
> out - the query works fine.
> If I switch my map projection to NAD 83 meters, then the postgis layers
> don't seem to reproject so they just don't show or show in very weird
> places.
> I'm assuming this is something wrong I'm doing with the postgis layers
> because if I swap these with map info tab files or shape files of NAD 83
> ft,
> those seem to work fine and project if I put in a PROJECT END clause.  I
> tried putting in a PROJECT  END .. in the postgis layers, but that didn't
> seem to make a difference.  I verified that my spatial fields are in the
> geometry_columns table.
> Below is a snippet of some of my mapfile
> CONFIG PROJ_LIB "E:\DNDIntranet\mapserv\scripts\proj\"
> CONFIG GDAL_DRIVER_PATH "E:\DNDIntranet\mapserv\scripts\fw\gdal_plugins\"
> NAME REMSPROP
> #meters EXTENT  225033.887 885954.489 245303.531 905462.069
> EXTENT  738152.213543900 2907686.126484261 797440.9488538101
> 2970773.30444638
> SIZE 500 500
> SHAPEPATH "F:\Mapservdata"
> UNITS feet
> SYMBOLSET symbols/symbols35.sym
> FONTSET symbols/fonts/font.lst
> IMAGETYPE jpeg
> TEMPLATEPATTERN "printable.html|loader.html|blankloader.htm"
> PROJECTION
>  "init=epsg:2249"
>  #"init=epsg:26986"
> END
> LAYER
>  NAME "bosaerial2001"
>  STATUS DEFAULT
>  TILEINDEX "bostonsidtiles.shp"
>  TILEITEM "Location"
>  MINSCALE 300
>  MAXSCALE 5000
>  TYPE RASTER
>  PROJECTION
>    "init=epsg:26986"
>  END
>  PROCESSING "COLOR_MATCH_THRESHOLD=6"
>  PROCESSING "SCALE_1=0,255"
>  PROCESSING "SCALE_2=0,255"
>  PROCESSING "SCALE_3=0,255"
> END
> LAYER
> NAME "neighborhoods"
> CONNECTIONTYPE postgis
> DATA "the_geom from neighborhoods"
> CONNECTION "user=propuser dbname=dnddts host=localhost"
> # PROJECTION
> #AUTO
> # "init=epsg:2249"
> # END
> TYPE POLYGON
> STATUS default
> CLASS
> OUTLINECOLOR 30 0 0
> END
> END
> LAYER
>   NAME "parcels"
>   DATA "the_geom from landparcels USING UNIQUE parcel_id"
>   STATUS DEFAULT
>   TYPE POLYGON
>   MAXSCALE 5000
>   CLASS
> NAME "Parcel Footprint"
> OUTLINECOLOR 100 100 200
> LABEL
>   POSITION CL
>   SIZE MEDIUM
>   COLOR 0 150 0
> END
>   END
>   TEMPLATE loader.html
> END
> Message: 7
> Date: Mon, 09 May 2005 17:10:09 +0200
> Message-ID: <1115651409.1274.34.camel at geru-itea>
>> -Steve
> Hi Steve,
> Didrik
> Name: not available
> Url :
> http://lists.refractions.net/pipermail/postgis-users/attachments/20050509/5a8f6478/attachment-0001.bin
> Message: 8
> Date: Mon, 9 May 2005 17:25:40 +0200
> From: strk at refractions.net
> Subject: Re: [postgis-users] pgsql2shp changing case of fieldnames
> To: "'PostGIS Users Discussion'"
> Message-ID: <20050509152540.GA98527 at keybit.net>
> Content-Type: text/plain; charset=us-ascii
>> the
>> names
>> revert
>> Thanks,
>> Regina
> Which version of pgsql2shp doesn't do that ?
> I guess we can revert the change back ... or add a -k switch
> to it as well.
> Does anyone see a problem with this ?
> --strk;
> Message: 9
> Date: Mon, 09 May 2005 18:46:15 +0200
> Message-ID: <1115657175.1274.38.camel at geru-itea>
> Le lundi 09 mai 2005 à 18:10 +0200, Nicol Hermann a écrit :
>> Hi Didrik,
>> did you try:
>> EXPRESSION ('[moved]' = 't')
>> or
>> EXPRESSION ("[TYPE]" = "Paved")
>> with the string conversion?
>> HTH
>> Nicol
> That solved the problem !!!!!
> Many many thanks !
> Didrik
> Name: not available
> Url :
> http://lists.refractions.net/pipermail/postgis-users/attachments/20050509/b129fdc2/attachment.bin
> End of postgis-users Digest, Vol 31, Issue 23
