[postgis-users] Problem installing postgis 1.0.0 - libgeos.so.2:cannot open shared object file
Jean David TECHER
davidtecher at yahoo.fr
Tue May 10 02:37:02 PDT 2005
as root
see if U have the line
/usr/local/lib
in file "/etc/ld.so.conf"
else add it then do
ldconfig
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
----- Original Message -----
To: postgis-users at postgis.refractions.net
Sent: Tuesday, May 10, 2005 11:37 AM
Subject: [postgis-users] Problem installing postgis 1.0.0 - libgeos.so.2:cannot open shared object file
Hi List,
I have problem after installing postgis 1.0.0:
- I installed the actual version of geos (V 2.1.1 - stable)
- After that I set LDFLAGS=-lstdc++ and compiled
postgresql --with-perl --with-openssl and installed it succesfully
- then I cpied the unzipped postgis-dir in the postgresql-contrib-folder of
my postgresql-source
- I modified Makefile.config (PROJ=1 GEOS=1)
- I compiled postgis (make install)
- I created a testdb (named postgis)
- I did a createlang plpgsql postgis
everything works so far
but when I try:
postgres at maas:/usr/local/pgsql> bin/psql -f share/contrib/lwpostgis.sql -d
postgis
Password:
BEGIN
NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
psql:share/contrib/lwpostgis.sql:36: NOTICE: type "histogram2d" is not yet
defined
ERROR: could not load library "/usr/local/pgsql/lib/liblwgeom.so.1.0":
libgeos.so.2: cannot open shared object file: Datei oder Verzeichnis nicht
gefunden
psql:share/contrib/lwpostgis.sql:36: ERROR: could not load library
"/usr/local/pgsql/lib/liblwgeom.so.1.0": libgeos.so.2: cannot open shared
object file: Datei oder Verzeichnis nicht gefunden
ERROR: current transaction is aborted, commands ignored until end of
transaction block
psql:share/contrib/lwpostgis.sql:41: ERROR: current transaction is aborted,
commands ignored until end of transaction block
transaction block
psql:share/contrib/lwpostgis.sql:49: ERROR: current transaction is aborted,
transaction block
psql:share/contrib/lwpostgis.sql:66: ERROR: current transaction is aborted,
transaction block
psql:share/contrib/lwpostgis.sql:71: ERROR: current transaction is aborted,
transaction block
psql:share/contrib/lwpostgis.sql:78: ERROR: current transaction is aborted,
it doesn't add the postgis-functions to my database
What's wrong ??
I also added /usr/locyl/pgsql/lib to my /etc/ld.so.conf and did a
/sbin/ldconfig
still got the same problem
Marco
P.S. system is a SuSE-Linux 8.2
Marco Lechner
dienstlich:
Institut für Physische Geographie
Uni Freiburg
Werderring 4
79085 Freiburg
Fon 0761 / 203-3548
Mail marco.lechner at geographie.uni-freiburg.de
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050510/4c5a973d/attachment.html>
