[postgis-users] Geomtry_columns may not have an oid
strk at refractions.net
Tue May 10 05:54:24 PDT 2005
Ok. Next release will have OID usage forced.
Both 1.0 and HEAD branches updated like this.
I wouldn't know where to put the workaround documentation, hopefully
affected people are ok with this list's archive.
--strk;
On Tue, May 10, 2005 at 12:19:09PM +0100, Mark Cave-Ayland wrote:
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of strk at refractions.net
> > Sent: 10 May 2005 11:41
> > To: 'PostGIS Users Discussion'
> > Subject: Re: [postgis-users] Geomtry_columns may not have an oid
> > On Tue, May 10, 2005 at 10:54:36AM +0100, Mark Cave-Ayland wrote:
> > > I haven't looked at the proposed patch but geometry_columns is
> > > effectively a "system" table in the context of PostGIS
> > anyway. I would
> > > agree and say force the creation of the geometry_columns table WITH
> > > OIDS.
> > Ok, I think we should do it as soon as possible so that in
> > the event pgsql will change default table creation policy
> > geometry_columns will not be affected. I'd use explicit OID
> > request in 1.0.1
> > This would be a change in the .sql file, but I think we can
> > avoid incrementing script version number (thus requiring user
> > to dump/reload). Do you agree ?
> Hi strk,
> I agree. I think that most people who have default installations won't be
> affected by this until 8.1 so we should be ok. According to the docs there
> is no way of adding OIDS back to a table once they have been removed, so the
> documented workaround for people already in this situation would have to be
> something like:
> BEGIN;
> ALTER TABLE geometry_columns RENAME TO old_geometry_columns;
> CREATE TABLE geometry_columns WITH OIDS AS (SELECT * FROM
> old_geometry_columns);
> DROP TABLE old_geometry_columns;
> COMMIT;
> (I gave this a quick test under 8.0 and it seemed to work for me)
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 791021
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> postgis-users mailing list
