[postgis-users] pgsql2shp changing case of fieldnames
strk at refractions.net
Tue May 10 11:42:12 PDT 2005
I've added the request in the HEAD branch TODO list.
If you will do it yourself sooner then us
we'll accept patches. Let me know if you plan to do it
and feel free to ask any info you might need for that.
--strk;
On Mon, May 09, 2005 at 04:02:46PM -0400, Obe, Regina DNDMIS wrote:
> The old one I had was dated sometime in 2003 and was compiled under cygwin,
> but it still seemed to work when I upgraded to 8.0. I think a -k switch
> would be best.
> The older version preserved the case that was in postgres so for situations
> where we needed UPPERCASE (standard shp behavior) we had to create views
> that had the fields upper cased and dumped those out; so this new version
> irradicates that need. There are some situations where it is convenient to
> keep the same case as postgres - e.g. it makes it easier to swap out a
> postgis layer with a shape layer where postgis is not feasible for a
> particular environment. I'm assuming mapserver is still case sensitive with
> field names in templates.
> -----Original Message-----
> From: strk at refractions.net [mailto:strk at refractions.net]
> Sent: Monday, May 09, 2005 11:26 AM
> To: 'PostGIS Users Discussion'
> Subject: Re: [postgis-users] pgsql2shp changing case of fieldnames
> On Mon, May 09, 2005 at 10:18:52AM -0400, Obe, Regina DNDMIS wrote:
> > I noticed the 3/31/05 build of pgsql2shp I have now automatically
> > forces the output field names to upper case which normally would be a
> > good thing. Unfortunately I've got some old mapserver maps that rely
> > on the field names in the dbf being in lowercase. Is there anyway to
> > reverse this behavior e.g. with a switch or something of that sort so
> > that I don't have to revert back to the older version of pgsql2shp?
> > Thanks,
> > Regina
> Which version of pgsql2shp doesn't do that ?
> I guess we can revert the change back ... or add a -k switch
> to it as well.
> Does anyone see a problem with this ?
> --strk;
> postgis-users mailing list postgis-users at postgis.refractions.net
