[postgis-users] Upper/lower case mismatch with postgis layers in mapserver
Daniel
daniel.faivre at camptocamp.com
Thu May 12 02:29:10 PDT 2005
Hello,
I encounter a problem with a PostGIS layer defined for mapserver with:
DATA "geom from user_FT000001.annuaire"
Mapserver send the request to PostGIS with the schema name in lowercase
(user_ft000001).
But I need to have it in uppercase to comply with the externally defined
database structure ...
Is there a way to have this working without writing a full "select from"
clause ?
Nota:
1) I've tried to quote the schema name -> crash
2) I've posted this on the mapserver list before ...
Daniel FAIVRE
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050512/13b2408d/attachment.vcf>
