[postgis-users] PostGIS CVS on Windows...OK
strk at refractions.net
Thu May 12 02:45:38 PDT 2005
I committed your line globally (it's not mingw specific).
Thanks.
Now the question is... how many archs are still around to
support ? Which is: on which OS are you postgis-users
running it ?
--strk;
On Thu, May 12, 2005 at 11:28:31AM +0200, Jean David TECHER wrote:
> Hi Sandro
> I downloaded the last PostGIS CVS...from less than a hour
> thanks for the changes U did in postgis/configure.in.... :-)
> The last change I did was about adding the following line after line 244 (for MinGW) (thanks Gerald)
> PGBELIBS ="-L$( echo $(${PGCONFIG} --libdir)) -lpostgres"
> All works fine now:
> - Regression tests (postgis/regress)
> - Loader (shp2pgsql)
> - Dumper (pgsql2shp)
> TECHER Jean David
> 01MAP
> e-mail: david at 01map.net
> Tél: 04 67 45 60 27
> Entreprise: http://www.01map.net
> Perso: http://techer.pascal.free.fr/postgis/
> postgis-users mailing list
