[postgis-users] PostGIS CVS on Windows...OK
Jean David TECHER
davidtecher at yahoo.fr
Thu May 12 08:32:08 PDT 2005
Hi Sandro
My friend Gerald has done the test for MAc OS X on is I-Book G4...
He will send U the patch in a few minutes...
Thanks
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
----- Original Message -----
To: PostGIS Users Discussion
Sent: Thursday, May 12, 2005 11:45 AM
Subject: Re: [postgis-users] PostGIS CVS on Windows...OK
I committed your line globally (it's not mingw specific).
Thanks.
Now the question is... how many archs are still around to
support ? Which is: on which OS are you postgis-users
running it ?
--strk;
On Thu, May 12, 2005 at 11:28:31AM +0200, Jean David TECHER wrote:
> Hi Sandro
> I downloaded the last PostGIS CVS...from less than a hour
> thanks for the changes U did in postgis/configure.in.... :-)
> The last change I did was about adding the following line after line 244 (for MinGW) (thanks Gerald)
> PGBELIBS ="-L$( echo $(${PGCONFIG} --libdir)) -lpostgres"
> All works fine now:
> - Regression tests (postgis/regress)
> - Loader (shp2pgsql)
> - Dumper (pgsql2shp)
> TECHER Jean David
> 01MAP
> Tél: 04 67 45 60 27
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050512/bbe3b8ed/attachment.html>
