[postgis-users] PostGIS CVS on Windows...OK
Jean David TECHER davidtecher at yahoo.fr
Thu May 12 03:25:24 PDT 2005
Yes Master
My friend Gerald is OK to do the tests...for geos 2.1.1, proj 4.4.9, postgresql 8.0.2 and postgis cvs
He will send U a trace.log
The logs will be in http://01map.net /macosx
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
  ----- Original Message -----
  To: PostGIS Users Discussion
  Sent: Thursday, May 12, 2005 12:09 PM
  Subject: Re: [postgis-users] PostGIS CVS on Windows...OK
  Can you test on Mac OS X ?
  --strk;
  On Thu, May 12, 2005 at 12:01:05PM +0200, Jean David TECHER wrote:
  > Good question!!!
  > I think the most popular OS are Unix and Linux
  > In order to answering to your question, as postgis-users
  >  at job we (me and gerald) work with Debian - Arch 32 and AMD 64 -, Windows XP, Gentoo, fedora core 3
  > We have  Mac OS X too (Unix)
  > So I think we could suppose that the OS most used are Unix, Linux and Windows
  > TECHER Jean David
  > 01MAP
  > Tél: 04 67 45 60 27
  >   From: strk at refractions.net
  >   Sent: Thursday, May 12, 2005 11:45 AM
  >   I committed your line globally (it's not mingw specific).
  >   Thanks.
  >   Now the question is... how many archs are still around to
  >   support ? Which is: on which OS are you postgis-users
  >   running it ?
  >   --strk;
  >   On Thu, May 12, 2005 at 11:28:31AM +0200, Jean David TECHER wrote:
  >   > Hi Sandro
  >   > I downloaded the last PostGIS CVS...from less than a hour
  >   > thanks for the changes U did in postgis/configure.in.... :-)
  >   > The last change I did was about adding the following line after line 244 (for MinGW) (thanks Gerald)
  >   >      PGBELIBS ="-L$( echo $(${PGCONFIG} --libdir)) -lpostgres"
  >   > All works fine now:
  >   > - Regression tests (postgis/regress)
  >   > - Loader (shp2pgsql)
  >   > - Dumper (pgsql2shp)
  >   > TECHER Jean David
  >   > 01MAP
  >   > Tél: 04 67 45 60 27
  >   > _______________________________________________
  >   > postgis-users mailing list
  >   > postgis-users at postgis.refractions.net
  >   > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050512/638e3d6d/attachment.html>
