[postgis-users] PostGIS CVS on Windows...OK
strk at refractions.net
Thu May 12 03:09:40 PDT 2005
Can you test on Mac OS X ?
--strk;
On Thu, May 12, 2005 at 12:01:05PM +0200, Jean David TECHER wrote:
> Good question!!!
> I think the most popular OS are Unix and Linux
> In order to answering to your question, as postgis-users
> at job we (me and gerald) work with Debian - Arch 32 and AMD 64 -, Windows XP, Gentoo, fedora core 3
> We have Mac OS X too (Unix)
> So I think we could suppose that the OS most used are Unix, Linux and Windows
> TECHER Jean David
> 01MAP
> e-mail: david at 01map.net
> Tél: 04 67 45 60 27
> Entreprise: http://www.01map.net
> Perso: http://techer.pascal.free.fr/postgis/
> ----- Original Message -----
> From: strk at refractions.net
> To: PostGIS Users Discussion
> Sent: Thursday, May 12, 2005 11:45 AM
> Subject: Re: [postgis-users] PostGIS CVS on Windows...OK
> I committed your line globally (it's not mingw specific).
> Thanks.
> Now the question is... how many archs are still around to
> support ? Which is: on which OS are you postgis-users
> running it ?
> --strk;
> On Thu, May 12, 2005 at 11:28:31AM +0200, Jean David TECHER wrote:
> > Hi Sandro
> > I downloaded the last PostGIS CVS...from less than a hour
> > thanks for the changes U did in postgis/configure.in.... :-)
> > The last change I did was about adding the following line after line 244 (for MinGW) (thanks Gerald)
> > PGBELIBS ="-L$( echo $(${PGCONFIG} --libdir)) -lpostgres"
> > All works fine now:
> > - Regression tests (postgis/regress)
> > - Loader (shp2pgsql)
> > - Dumper (pgsql2shp)
> > TECHER Jean David
> > 01MAP
> > Tél: 04 67 45 60 27
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
