[postgis-users] Upper/lower case mismatch with postgis layers in mapserver
Bill Binko bill at binko.net
Thu May 12 10:59:52 PDT 2005
On Thu, 12 May 2005, Daniel wrote:
> Hello,
> I encounter a problem with a PostGIS layer defined for mapserver with:
> DATA "geom from user_FT000001.annuaire"
> Mapserver send the request to PostGIS with the schema name in lowercase
> (user_ft000001).
> But I need to have it in uppercase to comply with the externally defined
> database structure ...
> Is there a way to have this working without writing a full "select from"
> clause ?
Not trying to say this isn't a bug, but have you tried this:
DATA "geom FROM (SELECT geom, oid FROM user_FT000001.annuaire) AS foo
USING UNIQUE oid USING SRID = <YOUR SRID HERE>"
Two others to try would be
DATA "geom FROM \"user_FT000001\".annuaire"
and
DATA "geom FROM (SELECT geom, oid FROM \"user_FT000001\".annuaire) AS foo
Please post the results of these: perhaps we can find a solution
Bill
