[postgis-users] The patch for macosx compilation
Jean David TECHER
davidtecher at yahoo.fr
Fri May 13 01:32:35 PDT 2005
however it's better to ask postgis-users...fo doc
perhaps better to prevent from to do the doc from general makefile
even if as U said postgis came with pre-build documentation
For me, better to see if docbook and xsltproc is installed
by configure or user as said gerald enable from configure the option '--with--doc'
what do U think??
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
----- Original Message -----
To: Gérald Fenoy
Cc: PostGIS Users Discussion
Sent: Friday, May 13, 2005 9:40 AM
Subject: Re: [postgis-users] The patch for macosx compilation
On Thu, May 12, 2005 at 04:27:28PM +0200, Gérald Fenoy wrote:
> Does anyone can make doc generation as an optional feature please
> (something like --with-doc maybe, if you want me and david can do this
> ... just tell us ;) ) ?
Postgis releases come with pre-build documentation and a make clean
should not drop it (make maintainer-clean does). So unless you
call make maintainer-clean you should not need docbook installed.
If this behaviour is tested to be non-stable I'd just remove 'docs'
from the default rules to run on 'make'.
--strk;
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050513/d4daef45/attachment.html>
