[postgis-users] docbook requirement
strk at refractions.net
Fri May 13 01:51:42 PDT 2005
On Fri, May 13, 2005 at 10:32:35AM +0200, Jean David TECHER wrote:
> however it's better to ask postgis-users...fo doc
> perhaps better to prevent from to do the doc from general makefile
> even if as U said postgis came with pre-build documentation
> For me, better to see if docbook and xsltproc is installed
> by configure or user as said gerald enable from configure the option '--with--doc'
> what do U think??
Sounds fair, but again, I wouldn't mind IFF current release
process works. If we want to help testing it we might add
the produced documentation in CVS as we did for generated
parser code.
--strk;
