[postgis-users] PostGIS CVS on Windows...OK
strk at refractions.net
Sat May 14 01:24:32 PDT 2005
On Fri, May 13, 2005 at 11:45:30PM +0300, alex bodnaru wrote:
> hi friends,
> i have had some limited access to a mips64.
> postgis built ok on it.
> but postgresql crashed when i attempted to run regression tests.
> regards,
> alex
Can you isolate the query generating the crash ?
Are you talking about 1.1.0CVS or 1.0.0 ?
In the former case, can you report value os HOST_OS
as detected by ./configure ?
Thanks!
--strk;
> On Fri, 2005-05-13 at 10:38 +0100, Andrew Seales wrote:
> > strk at refractions.net wrote:
> > >Now the question is... how many archs are still around to
> > >support ? Which is: on which OS are you postgis-users
> > >running it ?
> postgis-users mailing list
