RES: [postgis-users] User Friendly vs Explicit
Bart van den Eijnden
bartvde at xs4all.nl
Mon May 16 12:06:58 PDT 2005
The EPSG database already has Access forms inside it for finding SRS
codes. AFAIK PostGIS SRID is the same code as the EPSG code.
http://www.epsg.org/
Also, I usually search the epsg text file distributed with PROJ 4 to find
an SRS code.
Best regards,
Bart
On Mon, 16 May 2005 21:02:37 +0200, Mike Leahy <mgleahy at fes.uwaterloo.ca>
wrote:
> I'm just wondering if there is a listing anywhere that makes it
> relatively easy to look-up SRIDs. In the spatial_ref_sys table there
> are over 2600 records, and after a bit of searching around, I've found
> that if somebody wanted to find the the appropriate SRID for a
> particular projection in PostGIS the only way to find it (that I can
> see) is to search through this table in PostGIS/PostgreSQL. Maybe it
> would be useful to make a more readable document, or maybe a web-page
> somewhere that allows users to browse the spatial_ref_sys table in a
> more user-friendly way, or perhaps such a thing already exists and I
> just don't know what to look for.
> Mike
> Gustavo Henrique Sberze Ribas wrote:
>> Some links about projections and the Earth:
>> The Earth:
>> http://www.gfz-potsdam.de/news/foto/images/GFZ-Potsdam-PR-20030122-Geoid-Undulation-1250x1250.jpg
>> How to map the Earth:
>> http://kartoweb.itc.nl/geometrics/Reference%20surfaces/body.htm
>> http://exchange.manifold.net/manifold/manuals/5_userman/mfd50The_Earth_as_an_Ellipsoid.htm
>> http://solid_earth.ou.edu/notes/geoid/earths_geoid.htm
>> Map Projections:
>> http://www.fes.uwaterloo.ca/crs/geog165/mapproj.htm
>> Check the Data Standards section:
>> http://maic.jmu.edu/sic/topics.htm
>> Gustavo
>> -----Mensagem original-----
>> De: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net]Em nome de Mark
>> Fenbers
>> Enviada em: sábado, 14 de maio de 2005 20:17
>> Para: PostGIS Users Discussion
>> Assunto: Re: [postgis-users] User Friendly vs Explicit
>> Mark Fenbers wrote:
>> Norman Vine wrote:
>> This is commonly referred to as the Vornoi Diagram
>> http://www.cs.cornell.edu/Info/People/chew/Delaunay.html
>> program that can compute this for you
>> http://www-2.cs.cmu.edu/~quake/triangle.html
>> Wow! I never knew this had a name! Your info was interesting and
>> helpful, but I want to calculate Voronoi Diagrams using PostGIS so that
>> all I have to pass around is some SQL to each site having different
>> radars to work with... I have yet to find documentation that makes it
>> clear to me why SRIDs (other than -1) are useful, and how to reproject
>> lat/lons into a planar projection. I see that the distance() function
>> also needs reprojected data to be useful...
>> OK, well, reading through more documentation and online stuff, I
>> learned of a spatial_ref_sys.sql file that wasn't run during
>> installation. So now I have the spatial_ref_sys table populated and
>> now understand that SRID relates to different map projections. But
>> this brings up even more questions, like "How in the world
>> (figuratively) will I be able to pick an SRID that's right for the work
>> I am doing?" And is the use of SetSRID() what actually reprojects my
>> data?
>> Mark
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
