[postgis-users] Can't make sense of this error
strk at refractions.net strk at refractions.net
Tue May 17 09:18:01 PDT 2005
On Tue, May 17, 2005 at 03:14:24PM +0200, "R. Müller" wrote:
> the same for me,
> is there any posibility to validate the geometries ?
WHERE isvalid(base_geom) AND isvalid(x_geom);
If isvalid() raises an ERROR that's a bug.
--strk;
> thanks
> ronald
> Mark Fenbers wrote:
> >I'm consistently getting an error that I cannot make sense of.  Here's
> >the query I run:
> >SELECT 'ILN' AS "base radar",radid,
> >    npoints(
> >            Difference(
> >                base_geom,
> >                x_geom
> >    FROM MJF WHERE radid != 'ILN';
> >Here's the error I get::
> >NOTICE:  TopologyException: no outgoing dirEdge found (34380.5,521104)
> >ERROR:  GEOS difference() threw an error!
> >If I change my WHERE clause such that only one row is returned instead
> >(e.g., unnegate the equality), then I do NOT get the error.  I get the
> >error whether I use Difference(), Intersection(), GeomUnion(), or the
> >like.   The 'base_geom' contains a circular geometry returned from the
> >Buffer() function (to create a disk around point).  The x_geom is a
> >rectangle that I know intersects the circle (base_geom).  Any ideas how
> >to interpret this error?
> >Mark
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
