[postgis-users] Can't make sense of this error
"R. Müller" r.mueller at unicomp-berlin.de
Tue May 17 06:14:24 PDT 2005
the same for me,
is there any posibility to validate the geometries ?
thanks
ronald
Mark Fenbers wrote:
> I'm consistently getting an error that I cannot make sense of.  Here's
> the query I run:
> SELECT 'ILN' AS "base radar",radid,
>     npoints(
>             Difference(
>                 base_geom,
>                 x_geom
>     FROM MJF WHERE radid != 'ILN';
> Here's the error I get::
> NOTICE:  TopologyException: no outgoing dirEdge found (34380.5,521104)
> ERROR:  GEOS difference() threw an error!
> If I change my WHERE clause such that only one row is returned instead
> (e.g., unnegate the equality), then I do NOT get the error.  I get the
> error whether I use Difference(), Intersection(), GeomUnion(), or the
> like.   The 'base_geom' contains a circular geometry returned from the
> Buffer() function (to create a disk around point).  The x_geom is a
> rectangle that I know intersects the circle (base_geom).  Any ideas how
> to interpret this error?
> Mark
> postgis-users mailing list
