[postgis-users] postgis_restore.pl patch to pass use strict;
James Marca
jmarca at translab.its.uci.edu
Tue May 17 12:48:53 PDT 2005
Hi. Appended is a patch to postgis_restore.pl for your consideration
which lets it run after adding
use strict;
to the top. I just added 4 "my"s inside of loops.
James
--- postgis-1.0.0/utils/postgis_restore.pl.orig 2005-05-16 15:53:19.000000000 -0700
+++ postgis-1.0.0/utils/postgis_restore.pl 2005-05-16 15:56:11.000000000 -0700
@@ -36,13 +36,13 @@
# pg_dump-743/pg743 => pg_restore-800/pg800
# pg_dump-800/pg800 => pg_restore-800/pg800
+use strict;
eval "exec perl -w $0 $@"
if (0);
(@ARGV == 3) || die "Usage: postgis_restore.pl <postgis.sql> <db> <dump>\nRestore a custom dump (pg_dump -Fc) of a postgis enabled database.\n";
-$DEBUG=1;
+my $DEBUG=1;
my %aggs = ();
my %fncasts = ();
@@ -127,7 +127,7 @@ while( my $line = <INPUT>)
my $geomfound = 0;
for (my $i=0; $i<@args; $i++)
- $arg = lc($args[$i]);
+ my $arg = lc($args[$i]);
#print "ARG1: [$arg]\n";
$arg =~ s/^ *//;
$arg =~ s/ *$//;
@@ -162,7 +162,7 @@ while( my $line = <INPUT>)
- $arg = $args[$i];
+ my $arg = $args[$i];
$arg = 'geometry' if ($arg eq 'oldgeometry');
$args[$i] = $arg;
@@ -342,7 +342,7 @@ while( my $line = <INPUT> )
my $wkbinvolved = 0;
$arg =~ s/^ *//;
$arg =~ s/ *$//;
$arg =~ s/^public.//;
@@ -354,7 +354,7 @@ while( my $line = <INPUT> )
$wkbinvolved++ if ( $arg eq 'wkb' );
- $args = join(', ', @args);
+ my $args = join(', ', @args);
#print "ARGS SCALAR: [$args]\n";
my $id = $funcname."(".$args.")";
#print "ID: [$id]\n";
@@ -392,7 +392,7 @@ while( my $line = <INPUT> )
my @args = split(",", $3);
$arg =~ s/^ *//;
$arg =~ s/ *$//;
@@ -402,7 +402,7 @@ while( my $line = <INPUT> )
$args[$i] = $arg;
my $id = $name."(".$args.")";
if ( $aggs{$id} )
