[postgis-users] postgis_restore.pl patch to pass use strict;
strk at refractions.net strk at refractions.net
Wed May 18 01:39:26 PDT 2005
Hi James,
I applied your patch, but before committing it can you remind
me the considerations you're talking about?
The eval part is there to allow a bourne
shell to run the script using perl interpreter (thus permitting
different installation paths for perl). `use strict' should be
*after* the eval for the thing to work.
--strk;
On Tue, May 17, 2005 at 12:48:53PM -0700, James Marca wrote:
> Hi.  Appended is a patch to postgis_restore.pl for your consideration
> which lets it run after adding
>   use strict;
> to the top.  I just added 4 "my"s inside of loops.
> James
> --- postgis-1.0.0/utils/postgis_restore.pl.orig	2005-05-16 15:53:19.000000000 -0700
> +++ postgis-1.0.0/utils/postgis_restore.pl	2005-05-16 15:56:11.000000000 -0700
> @@ -36,13 +36,13 @@
>  #	pg_dump-743/pg743 => pg_restore-800/pg800
>  #	pg_dump-800/pg800 => pg_restore-800/pg800
> +use strict;
>  eval "exec perl -w $0 $@"
>  	if (0);
>  (@ARGV == 3) || die "Usage: postgis_restore.pl <postgis.sql> <db> <dump>\nRestore a custom dump (pg_dump -Fc) of a postgis enabled database.\n";
> -$DEBUG=1;
> +my $DEBUG=1;
>  my %aggs = ();
>  my %fncasts = ();
> @@ -127,7 +127,7 @@ while( my $line = <INPUT>)
>  		my $geomfound = 0;
>  		for (my $i=0; $i<@args; $i++)
> -			$arg = lc($args[$i]);
> +			my $arg = lc($args[$i]);
>  			#print "ARG1: [$arg]\n";
>  			$arg =~ s/^ *//;
>  			$arg =~ s/ *$//;
> @@ -162,7 +162,7 @@ while( my $line = <INPUT>)
> -				$arg = $args[$i];
> +				my $arg = $args[$i];
>  				$arg = 'geometry' if ($arg eq 'oldgeometry');
>  				$args[$i] = $arg;
> @@ -342,7 +342,7 @@ while( my $line = <INPUT> )
>  		my $wkbinvolved = 0;
>  			$arg =~ s/^ *//;
>  			$arg =~ s/ *$//;
>  			$arg =~ s/^public.//;
> @@ -354,7 +354,7 @@ while( my $line = <INPUT> )
>  			$wkbinvolved++ if ( $arg eq 'wkb' );
> -		$args = join(', ', @args);
> +		my $args = join(', ', @args);
>  		#print "ARGS SCALAR: [$args]\n";
>  		my $id = $funcname."(".$args.")";
>  		#print "ID: [$id]\n";
> @@ -392,7 +392,7 @@ while( my $line = <INPUT> )
>  		my @args = split(",", $3);
>  			$arg =~ s/^ *//;
>  			$arg =~ s/ *$//;
> @@ -402,7 +402,7 @@ while( my $line = <INPUT> )
>  			$args[$i] = $arg;
>  		my $id = $name."(".$args.")";
>  		if ( $aggs{$id} )
> postgis-users mailing list
