[postgis-users] postgis_restore.pl patch to allow psql options
strk at refractions.net
Wed May 18 10:07:13 PDT 2005
On Tue, May 17, 2005 at 02:23:45PM -0700, James Marca wrote:
> Hi,
> Appended is a second (of three) patch to postgis_restore.pl. This
> patch copies the brief description at the top of the script into pod
> format (at the bottom), and inserts pod2usage() calls in place of the
> various "die" commands.
> James E. Marca
James, your first patch is in CVS so this doesn't cleanly apply
anymore. Before sending another, a couple of issues:
1) the #/bin/sh approach was a choice, we can change it
but would be a separate patch (IMO) as needs some more
discussion
2) It seems your patch has been implemented against an older
version, current one (CVS) uses additional command line
args as createdb_opts
The pod2usage seems ok to me as far as Pod::Usage is a default lib
and does not costitute any additional requirement. Can you confirm this ?
Thanks!
--strk;
> --- postgis-1.0.0/utils/postgis_restore.pl.usestrict 2005-05-16 15:59:22.000000000 -0700
> +++ postgis-1.0.0/utils/postgis_restore.pl 2005-05-17 14:15:58.000000000 -0700
> @@ -1,4 +1,4 @@
> -#/bin/sh
> +#!/usr/bin/perl -w
> # This script is aimed at restoring postgis data
> # from a dumpfile produced by pg_dump -Fc
> @@ -37,10 +37,13 @@
> # pg_dump-800/pg800 => pg_restore-800/pg800
> use strict;
> -eval "exec perl -w $0 $@"
> - if (0);
> +use warnings;
> +use Pod::Usage;
> -(@ARGV == 3) || die "Usage: postgis_restore.pl <postgis.sql> <db> <dump>\nRestore a custom dump (pg_dump -Fc) of a postgis enabled database.\n";
> +# eval "exec perl -w $0 $@"
> +# if (0);
> +(@ARGV == 3) || pod2usage(-exitstatus => 0, -verbose => 2);
> my $DEBUG=1;
> @@ -108,11 +111,19 @@ print "postgis.sql is $postgissql\n";
> print "dbname is $dbname\n";
> print "dumpfile is $dump\n";
> +# form the various client program commands, for use later
> +my $pg_restore_command= "pg_restore ";
> +my $createdb_command = "createdb ";
> +my $createlang_command = "createlang ";
> +my $psql_command = "psql ";
> # Scan postgis.sql
> print "Scanning $postgissql\n";
> -open( INPUT, $postgissql ) || die "Couldn't open file: $postgissql\n";
> +open( INPUT, $postgissql ) || pod2usage(-exitval => 2, -verbose => 0,
> + -msg => "Couldn't open file: $postgissql for reading\n") ;
> while( my $line = <INPUT>)
> $line =~ s/[\r\n]//g;
> @@ -302,8 +313,10 @@ close( INPUT );
> # Scan dump list
> print "Scanning $dump list\n";
> -open( OUTPUT, ">$dumplist") || die "Can't write to ".$dump.".list\n";
> -open( INPUT, "pg_restore -l $dump |") || die "Couldn't run pg_restore -l $dump\n";
> +open( OUTPUT, ">$dumplist") || pod2usage(-exitval => 2, -verbose => 0,
> + -msg => "Can't write to $dumplist\n");
> +open( INPUT, "$pg_restore_command -l $dump |") || pod2usage(-exitval => 2, -verbose => 0,
> + -msg => "Couldn't run $pg_restore_command -l $dump\n");
> while( my $line = <INPUT> )
> next if $line =~ /^;/;
> @@ -532,8 +545,10 @@ close( INPUT );
> close(OUTPUT);
> print "Producing ascii dump $dumpascii\n";
> -open( INPUT, "pg_restore -L $dumplist $dump |") || die "Can't run pg_restore\n";
> -open( OUTPUT, ">$dumpascii") || die "Can't write to $dumpascii\n";
> +open( INPUT, "$pg_restore_command -L $dumplist $dump |") || pod2usage(-exitval => 2, -verbose => 0,
> + -msg => "Can't run $pg_restore_command -L $dumplist $dump\n");
> +open( OUTPUT, ">$dumpascii") || pod2usage(-exitval => 2, -verbose => 0,
> + -msg => "Can't write to $dumpascii. \nCheck that the disk isn't full, and that you have permission to write to the current working directory\n");
> next if $line =~ /^ *--/;
> @@ -594,22 +609,27 @@ close(OUTPUT);
> # Create the new db and install plpgsql language
> print "Creating db ($dbname)\n";
> -`createdb $dbname`;
> -die "Can't restore in an existing database\n" if ($?);
> +`$createdb_command $dbname`;
> +pod2usage(-exitval => 2, -verbose => 0,
> + -msg => "Can't create database $dbname. \nCheck that the dbuser is correct, has permission to create tables, and that the database doesn't already exist\n" ) if ($?);
> print "Adding plpgsql\n";
> -`createlang plpgsql $dbname`;
> +`$createlang_command plpgsql $dbname`;
> # Open a pipe to the SQL monitor
> -open( PSQL, "| psql -a $dbname") || die "Can't run psql\n";
> +open( PSQL, "| $psql_command -a $dbname") || pod2usage(-exitval => 2, -verbose => 0,
> + -msg => "Can't run $psql_command -a $dbname \nCheck that the database user is correct, and that the hostname and port are correct\n");
> # Source new postgis.sql
> print "Sourcing $postgissql\n";
> -open(INPUT, "<$postgissql") || die "Can't read $postgissql\n";
> +open(INPUT, "<$postgissql") || pod2usage(-exitval => 2, -verbose => 0,
> + -msg => "Couldn't open file: $postgissql for reading, which is strange because it was read successfully earlier in this script.\n");
> while(<INPUT>) { print PSQL; }
> close(INPUT);
> @@ -628,7 +648,130 @@ print PSQL "DROP TABLE spatial_ref_sys;"
> # Source modified ascii dump
> print "Restoring ascii dump $dumpascii\n";
> -open(INPUT, "<$dumpascii") || die "Can't read $postgissql\n";
> +open(INPUT, "<$dumpascii") || pod2usage(-exitval => 2, -verbose => 0,
> + -msg => "Can't read $dumpascii, which is strange because it was just written earlier in this script. Perhaps the disk is full?\n");
> close(INPUT);
> close(PSQL);
> +1; # all done
> +__END__
> +=head1 NAME
> +postgis_restore.pl -- a script to restoring postgis data from a
> +dumpfile produced by pg_dump -Fc
> +=head1 SYNOPSIS
> + postgis_restore.pl [options] [postgis.sql] [db] [dump]
> +Arguments:
> + postgis.sql --- the new version of PostGIS SQL commands you wish
> + to use
> + db --- the new database name. This cannot be an existing database
> + dump --- the dump file created by pg_dump
> +=head1 ARGUMENTS
> +=over
> +=item B<postgis.sql>
> +When upgrading to a new version of PostGIS, this is the file that
> +contains the new PostGIS functions. For example, in PostGIS 1.0.0,
> +the file is called lwpostgis.sql.
> +=item B<db>
> +A database name for the database that will be created by this script.
> +Note that this script will fail if the database name already exists,
> +but you will have to wait around while the dump file is processed
> +first. If you want to reuse an old database name, run the dropdb
> +program before running this script. But be aware that dropdb really
> +B<drop>s your database, and there is no undo_mistake program!
> +=item B<dump>
> +The 'custom' dump file created by pg_dump. Given a database called
> +'olddb', one might run the following:
> + pg_dump -U postgres -W -f olddb.dump -Fc olddb
> +to get a dump file called olddb.dump
> +=back
> +=head1 DESCRIPTION
> +B<postgis_restore.pl> is aimed at restoring postgis data from a
> +Basically it will restore all but things created by the given
> +postgis.sql. Before restoring, it will create and postgis-enable the
> +target db.
> +Particular attention must be given to the spatial_ref_sys and
> +geometry_columns tables which are created and populated from the dump,
> +not the postgis.sql file. When the new installation is against
> +pgsql7.5+ and dump from pre7.5 this script should probably drop
> +statistic fields from that table. This is currently not done.
> +=head1 ISSUES
> +=over
> +=item B<OBSOLETED FUNCTIONS BEHAVIOR>
> +Some obsoleted functions would not be present in the postgis.sql, but
> +will be found in the dump. Currently some are skipped, but some depend
> +on the pg version so will issue an ERROR due to unavailability of
> +corresponding C function in postgis lib.
> +=item B<LESS IS MORE?>
> +This script could do less than it does, to allow users to further
> +modify the edited dump before feeding it to the restoring side.
> +=back
> +=head1 TESTED ON:
> +The original code was tested on the following platforms:
> +=over
> +=item pg_dump-734/pg734 => pg_restore-743/pg743
> +=item pg_dump-743/pg734 => pg_restore-743/pg743
> +=item pg_dump-743/pg743 => pg_restore-743/pg743
> +=item pg_dump-734/pg734 => pg_restore-800/pg800
> +=item pg_dump-743/pg734 => pg_restore-800/pg800
> +=item pg_dump-743/pg743 => pg_restore-800/pg800
> +=item pg_dump-800/pg800 => pg_restore-800/pg800
> +=back
> +Note that this version, which adds pod, pod2usage calls, and modifies
> +some small pieces of logic, has not been tested on these platforms.
> +=head1 AUTHOR
> +Unknown? Maintained by staff of Refractions Research.
> +=head1 AVAILABILITY
> +Included with PostGIS distribution. The best place to discuss
> +this script or to get help is on the PostGIS mailing list,
> +L<http://postgis.refractions.net/pipermail/postgis-users/>
> +=cut
> postgis-users mailing list
