[postgis-users] EPSG codes
Paul Ramsey
pramsey at refractions.net
Wed May 18 12:54:01 PDT 2005
I'm confused too... do you have a question? :)
If you want a spatial_ref_sys entry for the Teale_Albers NAD 27
coordinate system, posting at least the contents of the .prj file or a
web URL to a description would help.
Yours,
Paul
Stone, Matthew (DHS-CDIC) wrote:
> OK, I have seen some postings about this and am still confused. I have
> PostGIS installed and the spatial_ref_sys table is installed in my
> PostgreSQL v.8.0.3. I am using a projection that is not supported,
> Teale_Albers NAD 27 for California and see how I could make that entry
> into the spatial_ref_sys table. However, if I need to make a
> conversion, will this be supported since I assume this conversion method
> is not built into the GEOS library that was also installed….I am mainly
> trying to upload GIS data to my database for visualization in Geoserver
> right now, not attempting to have a user make conversions on the fly
> through a web app….
> Help…
> Matthew
> Matthew Stone, MPH
> UCSF/CA Dept. of Health Services
> Epidemiology and Program Evaluation Unit
> 1616 Capitol Ave MS 7212
> **Mailing Address:***
> *PO BOX 997413
> Sacramento CA 95899-7413
> **Physical Address:**
> 1616 Capitol Avenue, Suite 74.324, MS 7212
> Sacramento, CA 95814
> _____________________________
> PH: 916-552-9918
> FAX: 916-552-9911
> mstone at dhs.ca.gov
> postgis-users mailing list
