[postgis-users] Can't make sense of this error
Mike Leahy
mgleahy at fes.uwaterloo.ca
Thu May 19 04:15:51 PDT 2005
Mark,
If you're using thunderbird, then when you compose an email you can
select Options -> Format -> Plain Text Only. Mine is currently set to
auto detect...as far as I know, it works fine.
Mike
Mark Fenbers wrote:
> Hmmm. That's odd. I don't know what that is all about. I'm using
> Thunderbird as of about a week ago. I'll look into it immediately
> after sending this response...
> Mark
> (Actually, I just checked something before sending this and noticed
> that this thing called "vcard" was checked. I unchecked it. I see
> that vcard was one of the complaints, but I'm clueless about the other
> two. Does this fix the problem in thie current message? Let me
> know... I also looked ahead in my unread Inbox and found only one
> other reply which asked if I have validated the polygons. I have. I
> put IsValid() on both geometries in the WHERE clause. And the
> attempted operation works if it only returns one record. If it
> returns more than one, then ERROR! If it were a "valid" problem, it
> wouldn't work even for one, right?)
> strk at refractions.net wrote:
>>It is extremely uncomfortable for me reading and replying
>>to mail composed by attached text/html.
>>Following is what I see. Hitting 'v' would show me the parses
>>html but replying won't be able to quote original message.
>>I usually completely skip mails so formatted.
>>If I'm being lame please someone help me with this.
>>--strk;
>>Date: Mon, 16 May 2005 21:46:16 -0400
>>From: "Mark Fenbers" <Mark.Fenbers at noaa.gov>
>>Organization: DoC/NOAA/NWS/OHRFC
>>Subject: Re: [postgis-users] Can't make sense of this error
>>Reply-To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>>X-BeenThere: postgis-users at postgis.refractions.net
>>[-- Attachment #1 --]
>>[-- Type: text/html, Encoding: 7bit, Size: 2.4K --]
>>[-- text/html is unsupported (use 'v' to view this part) --]
>>[-- Attachment #2: Mark.Fenbers.vcf --]
>>[-- Type: text/x-vcard, Encoding: 7bit, Size: 0.3K --]
>>[-- text/x-vcard is unsupported (use 'v' to view this part) --]
>>[-- Attachment #3 --]
>>[-- Type: text/plain, Encoding: 7bit, Size: 0.2K --]
>>_______________________________________________
>>postgis-users mailing list
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050519/64690d6f/attachment.html>
