[postgis-users] Can't make sense of this error
Mark Fenbers Mark.Fenbers at noaa.gov
Thu May 19 05:00:53 PDT 2005
Mike, mine is set to auto-detect, too, and aside from strk's message, I
never knew of any problems on any postings I sent.  Apparently, strk is
still having problems even though I took out the vcard.  Did you have
any problems viewing my "Hmmm, That's odd" message?  I depend on answers
from this group, and certainly don't want to do anything to stiffle
responses from anyone.  But I'm not sure what needs to be done to
prevent the problem that strk is having with my e-mail.  strk, what
e-mail client are you using?  Does changing "auto-detect" to "Plain Text
only" work for you, strk?
Mark
Mike Leahy wrote:
> Mark,
> If you're using thunderbird, then when you compose an email you can
> select Options -> Format -> Plain Text Only.  Mine is currently set to
> auto detect...as far as I know, it works fine.
> Mike
> Mark Fenbers wrote:
>> Hmmm.  That's odd.  I don't know what that is all about.  I'm using
>> Thunderbird as of about a week ago.  I'll look into it immediately
>> after sending this response...
>> Mark
>> (Actually, I just checked something before sending this and noticed
>> that this thing called "vcard" was checked.  I unchecked it.  I see
>> that vcard was one of the complaints, but I'm clueless about the
>> other two.  Does this fix the problem in thie current message?  Let
>> me know...  I also looked ahead in my unread Inbox and found only one
>> other reply which asked if I have validated the polygons.  I have.  I
>> put IsValid() on both geometries in the WHERE clause.  And the
>> attempted operation works if it only returns one record.  If it
>> returns more than one, then ERROR!  If it were a "valid" problem, it
>> wouldn't work even for one, right?)
>> strk at refractions.net wrote:
>>>It is extremely uncomfortable for me reading and replying
>>>to mail composed by attached text/html.
>>>Following is what I see. Hitting 'v' would show me the parses
>>>html but replying won't be able to quote original message.
>>>I usually completely skip mails so formatted.
>>>If I'm being lame please someone help me with this.
>>>--strk;
>>>Date: Mon, 16 May 2005 21:46:16 -0400
>>>From: "Mark Fenbers" <Mark.Fenbers at noaa.gov>
>>>Organization: DoC/NOAA/NWS/OHRFC
>>>Subject: Re: [postgis-users] Can't make sense of this error
>>>Reply-To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>>>X-BeenThere: postgis-users at postgis.refractions.net
>>>[-- Attachment #1 --]
>>>[-- Type: text/html, Encoding: 7bit, Size: 2.4K --]
>>>[-- text/html is unsupported (use 'v' to view this part) --]
>>>[-- Attachment #2: Mark.Fenbers.vcf --]
>>>[-- Type: text/x-vcard, Encoding: 7bit, Size: 0.3K --]
>>>[-- text/x-vcard is unsupported (use 'v' to view this part) --]
>>>[-- Attachment #3 --]
>>>[-- Type: text/plain, Encoding: 7bit, Size: 0.2K --]
>>>_______________________________________________
>>>postgis-users mailing list
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050519/11892109/attachment.vcf>
