[postgis-users] Can't make sense of this error
strk at refractions.net
Thu May 19 05:12:52 PDT 2005
On Thu, May 19, 2005 at 08:00:53AM -0400, Mark Fenbers wrote:
> Mike, mine is set to auto-detect, too, and aside from strk's message, I
> never knew of any problems on any postings I sent. Apparently, strk is
> still having problems even though I took out the vcard. Did you have
> any problems viewing my "Hmmm, That's odd" message? I depend on answers
> from this group, and certainly don't want to do anything to stiffle
> responses from anyone. But I'm not sure what needs to be done to
> prevent the problem that strk is having with my e-mail. strk, what
> e-mail client are you using? Does changing "auto-detect" to "Plain Text
> only" work for you, strk?
I can fully read *this* message. Whatever you did it worked. Thank you.
--strk;
> Mark
> Mike Leahy wrote:
> >Mark,
> >If you're using thunderbird, then when you compose an email you can
> >select Options -> Format -> Plain Text Only. Mine is currently set to
> >auto detect...as far as I know, it works fine.
> >Mike
> >Mark Fenbers wrote:
> >>Hmmm. That's odd. I don't know what that is all about. I'm using
> >>Thunderbird as of about a week ago. I'll look into it immediately
> >>after sending this response...
> >>Mark
> >>(Actually, I just checked something before sending this and noticed
> >>that this thing called "vcard" was checked. I unchecked it. I see
> >>that vcard was one of the complaints, but I'm clueless about the
> >>other two. Does this fix the problem in thie current message? Let
> >>me know... I also looked ahead in my unread Inbox and found only one
> >>other reply which asked if I have validated the polygons. I have. I
> >>put IsValid() on both geometries in the WHERE clause. And the
> >>attempted operation works if it only returns one record. If it
> >>returns more than one, then ERROR! If it were a "valid" problem, it
> >>wouldn't work even for one, right?)
> >>strk at refractions.net wrote:
> >>>It is extremely uncomfortable for me reading and replying
> >>>to mail composed by attached text/html.
> >>>Following is what I see. Hitting 'v' would show me the parses
> >>>html but replying won't be able to quote original message.
> >>>I usually completely skip mails so formatted.
> >>>If I'm being lame please someone help me with this.
> >>>--strk;
> >>>Date: Mon, 16 May 2005 21:46:16 -0400
> >>>From: "Mark Fenbers" <Mark.Fenbers at noaa.gov>
> >>>Organization: DoC/NOAA/NWS/OHRFC
> >>>Subject: Re: [postgis-users] Can't make sense of this error
> >>>Reply-To: PostGIS Users Discussion
> >>><postgis-users at postgis.refractions.net>
> >>>To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> >>>X-BeenThere: postgis-users at postgis.refractions.net
> >>>[-- Attachment #1 --]
> >>>[-- Type: text/html, Encoding: 7bit, Size: 2.4K --]
> >>>[-- text/html is unsupported (use 'v' to view this part) --]
> >>>[-- Attachment #2: Mark.Fenbers.vcf --]
> >>>[-- Type: text/x-vcard, Encoding: 7bit, Size: 0.3K --]
> >>>[-- text/x-vcard is unsupported (use 'v' to view this part) --]
> >>>[-- Attachment #3 --]
> >>>[-- Type: text/plain, Encoding: 7bit, Size: 0.2K --]
> >>>_______________________________________________
> >>>postgis-users mailing list
> >>>http://postgis.refractions.net/mailman/listinfo/postgis-users
