[postgis-users] Still can't make sense of this error
Mark Fenbers
Mark.Fenbers at noaa.gov
Thu May 19 06:20:05 PDT 2005
OK, now that we got the source of the message garbage out ot the way, I
need to restate my unresolved problem...
I'm consistently getting an error that I cannot make sense of. Here's
the query I run:
SELECT 'ILN' AS "base radar",radid,
AsText(
Difference(
base_geom,
x_geom
FROM MJF WHERE radid != 'ILN'
AND IsValid(x_geom) AND IsValid(base_geom);
Here's the error I get::
NOTICE: TopologyException: no outgoing dirEdge found (34380.5,521104)
ERROR: GEOS difference() threw an error!
If I change my query such that only one row is returned (such as adding
"LIMIT 1", or changing the WHERE clause from "!=" to "="), then I do NOT
get the error. I get the error whether I use Difference(),
Intersection(), GeomUnion(), or the like, whenever more than one row is
returned. The 'base_geom' contains a circular geometry returned from
the Buffer() function (to create a disk around point). The x_geom is a
rectangle that I know intersects the circle (base_geom). Any ideas how
to interpret this error or get around it?
Mark
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050519/53aed3f2/attachment.vcf>
