[postgis-users] Aggregate Function Malfunction
Mark Fenbers
Mark.Fenbers at noaa.gov
Mon May 23 04:44:17 PDT 2005
I have a table populated with geometries (polygons to be exact) that
were created with other PostGIS functions. They were added to this
table after passing the IsValid() test. A SELECT query using IsValid()
verifies that all geometries in the table are valid. But when I run the
query,
SELECT Npoints( MultiIntersection( the_geom )) FROM myTable WHERE
IsValid(the_geom);
I get an error "parse error - invalid geometry". I cannot tell which
record is triggering the error because MultiIntersection() is an
*aggregate* function I created to take the cumulative Intersection() of
several polygons in the table (one per row). It is defined as such:
CREATE AGGREGATE MultiIntersection (
BASETYPE = GEOMETRY,
SFUNC = Intersection,
STYPE = GEOMETRY,
INITCOND = ''
I'm going on the assumption that, because this is my first attempt at my
own aggregate function, I am doing something incorrectly. But I can
figure out what it is I am doing wrong. Can you help, please?
Some of my cluelessness may be in part due to a lack of my understanding
the STYPE, and BASETYPE parameters as well as what the INITCOND setting
should be. I have not successfully found any documentation on these
other than syntax and examples.
Mark
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050523/99c6600b/attachment.vcf>
