[postgis-users] Aggregate Function Malfunction
Stephen Woodbridge
woodbri at swoodbridge.com
Mon May 23 05:24:19 PDT 2005
Mark,
Did you try something like:
SELECT IsValid( MultiIntersection( the_geom )) FROM myTable WHERE
IsValid(the_geom);
to see what it reports?
-Steve
Mark Fenbers wrote:
> I have a table populated with geometries (polygons to be exact) that
> were created with other PostGIS functions. They were added to this
> table after passing the IsValid() test. A SELECT query using IsValid()
> verifies that all geometries in the table are valid. But when I run the
> query,
> SELECT Npoints( MultiIntersection( the_geom )) FROM myTable WHERE
> IsValid(the_geom);
> I get an error "parse error - invalid geometry". I cannot tell which
> record is triggering the error because MultiIntersection() is an
> *aggregate* function I created to take the cumulative Intersection() of
> several polygons in the table (one per row). It is defined as such:
> CREATE AGGREGATE MultiIntersection (
> BASETYPE = GEOMETRY,
> SFUNC = Intersection,
> STYPE = GEOMETRY,
> INITCOND = ''
> I'm going on the assumption that, because this is my first attempt at my
> own aggregate function, I am doing something incorrectly. But I can
> figure out what it is I am doing wrong. Can you help, please?
> Some of my cluelessness may be in part due to a lack of my understanding
> the STYPE, and BASETYPE parameters as well as what the INITCOND setting
> should be. I have not successfully found any documentation on these
> other than syntax and examples.
> Mark
> postgis-users mailing list
