[postgis-users] Large geometry needs a lot of time to be inserted
Miguel R. Luaces luaces at enxenio.es
Fri May 27 04:23:07 PDT 2005
Dear all,
we have insertedd a very large geometry in a PostGIS database, and it has
needed an awful lot of time.
Particularly, the geometry is a multipolygon with 308986 points, and it has
needed 5803313 ms (over 90 minutes) in a modern computer (don't remember the
specs, but it is Pentium IV with 1 GB RAM).
Is this normal? Are we doing something wrong?
Version information:
PostgreSQL 8.0.1 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC) 3.4.2
(mingw-special)
"0.9 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
Thank you very much in advance. Best regards,
  Miguel
Dr. Miguel R. Luaces          luaces at enxenio.es
Enxenio SL                    http://www.enxenio.es
Estrada dos Baños de Arteixo, Edif. San Cristovo, Portal B, 2º Esq.
15008 A Coruña (Spain)        Tlf./Fax.: 981 913 768
